upgrading from l6 to l8 checklist
Old May 23, 2012 | 09:31 AM
rinus_2005's Avatar
rinus_2005
Default upgrading from l6 to l8 checklist
As above,
I want to upgrade to closed loop
All I need to do is: ?
-l8 ecu (with suitable chip)
-retrofit a knocksensor to the block (and wire it to the loom/ecu)
-fit a lambdasensor in the downpipe (and wire it to the loom/ecu)
-fit a pf09 tps, and swap the outer wires to the tps
Old May 23, 2012 | 09:57 AM
Stu @ M Developments's Avatar
PassionFords Creator
Correct mate, also well worth checking your power supply to the ECU and rewiring the fuel pump to a new circuit while your at it.
Old May 23, 2012 | 03:50 PM
rinus_2005's Avatar
rinus_2005
thanks, will check the rest as well
tankybaby66
Feb 6, 2016 02:24 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Sp3no
Sep 27, 2015 07:23 PM
focus2351
Sep 9, 2015 09:33 PM
