saphire 4x4 cosworth erratic rev counter
can anyone help my 4x4 saphire rev counter is jumping all over the place and is missing under boost any ideas
thanks anth
thanks anth
Last Time, Get Off PF FFS
Check your plugs first as it sounds like the boost is blowing out the spark. IMO me and most people use standard 071 sparkplugs as they are good enough. Not sure what to do about the rev counter. If that fails check all the sensors and whilst your at it give them a good wipe/clean up including your temp sensors at the back left handside of the head behind the dipstick.
Hope this helps.
Hope this helps.
Mine does this every now and then.
Must try the multiplug clean
JoeyBoyden
18-08-2015 05:56 PM
ekjim
17-08-2015 08:57 PM
cozzy jeff
14-08-2015 05:46 PM
