Various escort turbo parts
got loads of bits that are no longer req as project has taken a different direction
cosworth 4x4 turbo with nearly new -31 actuator £200
rs turbo chargecooler set up £150
rs1600 rocker cover in black £70
rs1600 inlet manifold with injector sandwich plate £25
cosworth management conversion inc
field motorsport cam sensor pick up(same as bombers)
field motorsport crank pulley set up(same as bomber)
efi inlet with cosworth throttle body and water and air temp sensor
loom (had insulation taken off was tested has all new plugs and new overbraid to do whole loom)
cosworth l6 ecu mapped for 1600cvh with yellows upto 25psi
brand new rs turbo dizzy
will throw in cvh cam cover and turbo cross over pipe for this setup
cosworth 4wd fuel pressure reg
£650
ford motorsport leads brand new £25
engine 1600 cvh
low comp bottom end done 3000mile
head is ported and polished with bigger valves
cvh35 cam kit inc springs and vernier pulley
new oil pump and water pump
arp rod bolts
arp head stud and nut kit
virtually brand new engine just the bottom ends done 3000 miles everything else and i mean everything else is brand new
£600
compomotive wheels 4
6.5j 15inch brand new in antercite
£300 cost over 600 and havent been used only put on car and pushed in and out the garage
£650
engine 1600 cvh
arp rod bolts
£600
muz
Aug 16, 2015 12:57 PM
