Focus and ST170 Parts
Parts with lots of pictures have links to their own album. Otherwise there are many pictures lower down the page. If you want more pictures just drop me a message and I will get them.
Well been breaking the car and heres some of the more important parts left. I will forget quite a few so PM me if you want something not listed. It was a ST170 conversion. Theres also many parts which I have got just lying around. All parts are based in Warwick.
Ghia alloys - Two tyres have 5mm, and two have 3mm. Wheels have some curbing and could do with a good clean. Make a good set of wheels for winter use or to put a car back to standard. £100
http://s153.photobucket.com/albums/s...oySilverFocus/
MK1.5 headlights. Two lugs on each light missing, one rear panel missing and no bulb holders. Still bolted in fine and all worked perfectly. £25 + postage
http://s153.photobucket.com/albums/s...mk15%20lights/
ST170 Complete Inlet. Has everything and is ready to use. Perfect for a individual throttle body conversion on a 1.8 or 2.0 engine. £100 + postage.
http://s153.photobucket.com/albums/s...31/st170inlet/
Alloy Wheels - Nearly new Toyo T1R tyres on these, 205 40 17. I believe two have 6mm and two have 5mm £180
http://s153.photobucket.com/albums/s224/ct7331/Alloys/
ST170 Steering Wheel - Pretty good condition £30
http://s153.photobucket.com/albums/s...ering%20wheel/
Rear Bumper - Its in hendrix style and includes both lights. Needs a respray. £100
ST170 Gearbox - 93,000 miles, not a single issue with the box. £80
ST170 spare wheel - unused by the looks of it £15 + postage
ST170 speedo + oil pressure and temp gauge. Mileage is around 93,000 mark. £30 + postage
ST170 ECU, loom and transponder - £50 + postage. Ideally want collection just incase that transponder breaks.
ST170 Front and Rear Shocks + Springs - £50
ST170 Steering Rack - Shorter full lock over standard rack - £30
ST170 Handbrake - £15
ST170 Door Handles - £15
ST170 Rocker Cover Gasket Bolt Set and Rubber Gaskets - £20
ST170 Interior Lights - Rear, Front Centre and two sunvisor lights - £20
ST170 Clutch - Tried to get pictures of how worn it is but it may be of use to someone - £20
ST170 Wiring Looms except the inlet and ecu loom - £50
Climate Control Dashboard Surround - £15
Standard Focus Upper Grille - £10
Standard Focus Slatted Lower Grille - £10
Sub and Enclosure - I believe it is a InPhase 1400W Sub, gives a very good amount of bass but sadly wont fit in my new car - £70
Headlight Flasher Kit, does each main beam bulb alternately like a police car - £15
Trip Computer Kit - Temperature Sensor, Washer bottle sensor and bottle, Trip Computer (has minor screen damage, not sure if it affects the unit), has some wiring needed. No Info Stalk! - £40
Doors - No bump strips, these have been removed and smoothed over professionally - £30 each
ST170 Engine Ancilleries - £30each
If there is anything else just drop me a message. Still plenty of stuff left.
Hi i am looking for a little thing but iuts the ST170 badge from the boot can you help
hope to hear from you
my email deanofinn~@yahoo.co.uk
[/quote]
[/quote]
Palethorpe01
15
Aug 18, 2015 06:09 AM
track.focus'd
Aug 12, 2015 05:53 PM
bumper, focus, ford, interior, passionford, pictures, rack, speedometer, spotlights, st170, steering, surround, swansea
