Sweedish plenium on 2wd
Just upgraded my 2wd to green injectors, 3bar map sensor, 31 actuator, big cooler, big filter and a stage 3 chip just waiting to get it set up now at sitech hopefully in the next few days but I've seen people going on about these different manifolds one of them being the sweedish plenium, what are these like and is it worth changing my standard one for one of these. I've seen one advertised and just thought hmmmmmmm. Lol cheers.
Ok thanks for that not wanting to buy unnecessary items that won't make any difference. They still look quite ok though lol. Would you or anyone else recommend putting a larger turbo on say a t4 or something.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Definately avoid Swedish plenums, you loose a lot of response/drivability.
Cheap upgrade is a 4x4 item, or if funds allow a Hart/Airtec one as recommended by Stu above.
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
dojj
28
Sep 11, 2015 10:00 PM
