Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Cannot Remove Battery From Mk 1 Focus 1.6
Old May 8, 2012 | 08:27 PM
wokeye's Avatar
wokeye
Default Cannot Remove Battery From Mk 1 Focus 1.6
The battery was flat on my Focus 1.6 Zetec and I wanted to remove it to try to charge it. However when I tried to remove the bolt that goes through the retaining strap with a 13mm socket it is just spinning. Looking at underneath the tray the bottom of the bolt is also turning so it is not snapped. It looks like whatever it screws into in the black plastic tray has snapped or something and is not unscrewing from it. I also have a Focus 2003 TDCI that has the same setup but the bolt came out no problem and was not just spinning. I managed to charge the battery by running an extension lead to the car but I guess that the battery has probably had it. It went flat after not using the car for 9 days.
Just wondered if anybody else had experience of this and could suggest a fix please?
Old May 8, 2012 | 08:30 PM
RichieST's Avatar
RichieST
Yes that happened to me a few years ago. Tried all sorts to get it out. Just had to end up cutting the strap to get the battery out, then a good strong bit of cord to secure the new battery or get the battery box out and replace / drill out and repair.
Old May 8, 2012 | 08:34 PM
GVK.'s Avatar
GVK.
Yep as above, need to cut the strap and then replace battery tray to fix it properly.
Quite common.
Old May 9, 2012 | 07:24 AM
wokeye's Avatar
wokeye
Ok thanks for the replies it's very useful I will try and source a used battery tray and if that is not available I will try and make my own retaining advice as I do not want to buy new from a main stealer.
Old May 9, 2012 | 01:13 PM
danme1987's Avatar
danme1987
I can supply full upper and lower battery tray. PM me
Old May 28, 2012 | 10:27 PM
Frsr's Avatar
Frsr
if you remove air filter box and look carefully you'll see a little black plastic stud poking thru where your battery strap ends push it down and in that will release the strap take battery out remove battery tray then drill out offending bolt !
Old Jun 18, 2012 | 06:05 PM
yunii's Avatar
yunii
Cool
i too had the same problem,so i cut strap went to breakers & got strap & tray to fit new battery. yunii
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Aug 29, 2015 08:16 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
