Air Filters & Hoses (nore added)
Old May 8, 2012 | 04:15 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default Air Filters & Hoses (nore added)
Pipercross foam filter fit standard inlet hose, a little battered as its been in the garage about 8 years lol £20+ post
Ramair foam filter just removed from car fits T34 70mm inlet, slight dent on neck £30+ post
Samco hose to fit above filter, few marks £20+ post
Roose standard intercooler to Small Turbo Escos TB £35
Samco Header Tank to Rad Pipe £15
180 Degree 16mm hose £5
Steve
Old May 23, 2012 | 08:58 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I also have the other 2 turbo hoses to make a full T34 set.
Will do all 3 hoses and the air filter for £70 + post or i can take it to the Classic Ford Show
Steve
Old May 23, 2012 | 09:03 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Here are the other 2 hoses
Steve
Old May 23, 2012 | 09:05 PM
langer's Avatar
langer
Is the t34 hose set bigger? Just iam planning on getting a t34 but just bought samcos
Old May 23, 2012 | 09:09 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Only the Air Filter hose is bigger on a T34
Steve
Old May 24, 2012 | 06:53 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Turbo to intercooler hose has a slight mark on it but does not leak
Steve
Old May 24, 2012 | 09:51 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default More Bits
PF01 TPS £20
Small Turbo Escos TPS £20
2wd Inlet Cam £25
4x4 Fuel Rail £25
Stainless battery clamp, new unused £4
Stainless Coil Can £4
Blue Dump Valve £10
All + post or i can take to Classic Ford
Steve
Johnny Knoxville
Sep 30, 2015 07:21 AM
mondeomark
Sep 28, 2015 06:28 AM
Russ Payne
Sep 25, 2015 08:29 PM
