hole in bottom of cozy water pump?
Old May 6, 2012 | 05:10 PM
richbogle's Avatar
richbogle
Default hole in bottom of cozy water pump?
Hi guys,i noticed a puddle under the saff thismorning,on further investigating i can see from underneith thers water cuming out a hole in water pump itself. Wots that all about?? And whats the script with the price of them,some are expensive!
Old May 6, 2012 | 05:56 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
pump is goosed
matt lewis for a proper cosworth pump
Old May 6, 2012 | 06:06 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the hole tells you the pump is fine when there is no water coming out of it
when water comes out of it the bearings in the pump are fucked but the pump is still pumping
time to get a new one in a hurry before you need a new engine
Old Oct 28, 2015 | 09:04 PM
M K's Avatar
M K
Just found this same issue, after doing a search for the problem,
Fine 1 day then bad leak from the bottom hole in 4x4 water pump! Annoyingly mine is more awkward as its machines to suit the 10stud set up
Old Oct 28, 2015 | 10:17 PM
Adam-M's Avatar
Adam-M
How old is your pump mate?
Old Oct 29, 2015 | 06:04 AM
M K's Avatar
M K
500 miles but car sat for 3 years
155lee
Sep 6, 2016 11:10 AM
155lee
Oct 27, 2015 04:55 AM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Bransby
Sep 11, 2015 09:12 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
