braided wiring overbraid temp and size?
Old May 4, 2012 | 12:23 AM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
Default braided wiring overbraid temp and size?
looking for bit of help
looking to make a harness for coilpack conversion on my Audi motor,
4 wires per coil, then 20 in total ( 4 wire, 5 coils) as pictured below (not my pic but same engine and coils/wiring)
Shopping list needed
what size overbraid will i need, downsizing from 2 wires to 4 and will 140degree be sufficiant as not to melt?
what gauge/amp rated wiring needs to be used?
erm, thats it i think!
any ideas or whatever appreciated!
Sean
Old May 4, 2012 | 12:32 AM
Cossie Sean
better pic!
Old May 4, 2012 | 12:55 AM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
rating of the wire depends on the current draw of each coil
overbraids usually are described as having a range of size, eg diameter 5-10mm etc as they expand. measure Outside diameter of your wire bunch and chose an appropriate braid size.
Again the braid manufacturer normally lists a temperature rating for the braiding.
Old May 4, 2012 | 12:56 AM
Psycho Warren
Carbon Crazy
oh yeah dont forget you will need the loom plugs, terminals and seals.
155lee
Oct 27, 2015 04:55 AM
alexbarnes95
11
Sep 15, 2015 10:26 AM
Mk5brown
Sep 9, 2015 12:52 PM
Ben26
Sep 3, 2015 07:55 PM
