Clutch bite adjustment is it poss
Old May 1, 2012 | 08:20 PM
ginner's Avatar
ginner
Default Clutch bite adjustment is it poss
As above is it poss on a 2wd Saph , if so how as mine is quite high up
Old May 1, 2012 | 08:37 PM
gibbo frst's Avatar
gibbo frst
have you tried re setting the ratchet .... mine did play up and have a high bite but reste once i gave the pedal a pull up..
Old May 2, 2012 | 07:46 AM
Mike1's Avatar
Mike1
You can try above the above.
Also, if you want to go over to a manually adjustable set-up there are parts available
http://www.randbmotorsport.co.uk/sho...?ProductID=386
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Fezman1
Oct 2, 2015 01:22 PM
sridgett
Oct 1, 2015 07:30 PM
