Mondeo TDCI Belt Tensioner Pulley
Old Apr 30, 2012 | 01:59 PM
deathrider666's Avatar
deathrider666
Damn Cars
Default Mondeo TDCI Belt Tensioner Pulley
Trying to change the alternator on my 2002 TDCI, I've managed to get the old one off but only managed to get the tension off the belt by undoing the bolt by the bottom of the alternator (it's the tensioner which is like a V shape with a pulley each end and a pivot point in the middle not the easier looking type which has the tensioner easily accessible at the bottom of the engine).
When I get the new alternator on, can I move the tensioner without buying a special tool that I've read about? Which way does the tensioner move, clockwise or anti?
Old Apr 30, 2012 | 02:46 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
i normally just use a prybar on the tenioner never had an issue just be carefull not to crack the edge
Old Apr 30, 2012 | 04:35 PM
deathrider666
Damn Cars
I've tried to get a crowbar on it and lever it against the engine mount to push it clockwise (near the bottom pulley) and anti clockwise (near the top pulley) but doesn't seem to move.
Which way is it meant to move?
Old Apr 30, 2012 | 08:46 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
It's a tricky one, and is definitely easier with the correct tool. Some people have made up a socket to fit, but you may find it easier to get the tool and sell it on eBay after.
Old Apr 30, 2012 | 09:32 PM
NEEDFORSPEED
OR put the belt on but off the top middle guide pulley and push the belt down onto it
Old May 1, 2012 | 02:52 PM
DanW@FastFord
Spelling Club King!
It's easiest as a two person job, and even with the tensioner 'untensioned' it's still a tight fit!
Old May 1, 2012 | 06:50 PM
plumbobing's Avatar
plumbobing
This is my next job for this week end, i can't be bothered to struggle with some dodgey tool so for £15 i couldn't say no to buying the proper tensioner tool.
One thing i would like to know though is the torque settings for all of the components of the auxiliary belt setup. Does anyone have any info on these please?
Old May 2, 2012 | 04:55 PM
GVK.'s Avatar
GVK.
Correct way of doing it is to remove the alternator, then the support bracket complete with the tensioner , swap the tensioner then refit the bracket etc.
Some people may 'cheat' by undoing the tensioner off the bracket in situ, but there is little room to get an Allen key in there to undo the bolt.
Alternator comes out between chassis and subframe once os track rod end is undone.
Alternator lower mounting studs 15nm
Alternator nuts and top bolt 47nm
Track rod end 40nm
Alternator support bracket - block bolts 47nm
Tensioner retaining bolt 23nm
Tensioner to alternator support bracket bolt 55nm
Idler bolt 48nm
Crank pulley bolts 45nm + 120 degrees.
BEFORE you take the belt off draw a picture of it's routing and note how the tensioner sits in the bracket as if you get it in the wrong place you won't get the belt on
Old May 3, 2012 | 08:33 PM
DanW@FastFord
Spelling Club King!
Or you'll spend bloody ages getting the braket back on only to realise that you haven't routed the belt through it, so have to take it all off again!
Old May 3, 2012 | 08:43 PM
GVK.'s Avatar
GVK.
Exactly that!
mark94
Oct 10, 2023 06:52 PM
wowk
Mar 30, 2021 07:49 PM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
The Enigma
Sep 29, 2015 10:31 AM
