Air filter placement
Hi advice needed on airfilter placement,
Not sure if to fit filter straight onto turbo's inlet or poistion it away from engine, may be round and below head light with a couple of holes in front pannel to let airflow to filter, will placeing the filter further away from turbo have any lag affect.
As you can see i have no inner wings so under bonnet temp shouldn't be to high, also the exhaust manifold is quite close to the coilover will the heat pass to this even with the air movment around it.
Johnny Knoxville
Sep 30, 2015 07:21 AM
