Gearbox - mk3 escort
Old Apr 28, 2012 | 08:28 PM
EscortCookie's Avatar
EscortCookie
Default Gearbox - mk3 escort
Hey guys, i'm having a little trouble with my escort's gearbox. When i shift into first, sometimes it misses first and goes into reverse, as the gearbox is quite loose & those two are quite close together. Does anyone know how to fix this?
Old Apr 28, 2012 | 08:35 PM
matts1's Avatar
matts1
could be linkage is worn mate, that would be my guess.
Old Apr 28, 2012 | 09:21 PM
EscortCookie
With the linkage, would it be much to replace?
Old Apr 29, 2012 | 11:43 AM
matts1's Avatar
matts1
been a long time since i had a mk3 but it wasnt much, you may be able to pick up a second hand one in working condition. Or there may be a kit with the bishes in so you can refurb it.
Pop on here as they look to be fitting one from a puma which will be easier to source.
http://www.seriesoneturbo.co.uk/show...hlight=linkage
at the very least, the site is very helpfull and all MK3 escort so people will have the bits you need if you replace like for like.
Old Apr 29, 2012 | 11:59 AM
studabear's Avatar
studabear
presume this is a 4speed box?
Old Apr 29, 2012 | 12:36 PM
EscortCookie
thank you, and yes it's a 4 speed, so it's slightly wierd for me to learn with. Also, it has no rev counter... Can i buy a rev counter?
Old Apr 29, 2012 | 12:45 PM
7sean7m7's Avatar
7sean7m7
You can either buy a rev counter that mounts where you like and wire it in, or buy some ghia/xr/rst clocks and wire them in.
Old Apr 29, 2012 | 01:51 PM
rsfido_1989's Avatar
rsfido_1989
Iv got a mk3 4 speed shifter on a car that's havin the engine removed
Old Apr 29, 2012 | 01:56 PM
bookwyse's Avatar
bookwyse
It all depends on wether the box or the mechanism has the reverse gate on it. Early model had the gate built into the stick mechanism under the gearstvcik and the later ones had it built into the gearbox.
If its in the stick its easy to fix, if its in the box then it is a box out job.
Old Apr 29, 2012 | 02:25 PM
rsfido_1989
I will have a 1100cc engine and 4 speed box and gear selector for grabs soon
Old Apr 29, 2012 | 02:51 PM
EscortCookie
how much would the gearbox be?
Old Apr 29, 2012 | 04:06 PM
rsfido_1989
With or without linkage? Where are you from?
Old Apr 29, 2012 | 05:17 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
I've got the box and linkage out of my mk3 cabby up for grabs if its any good? Ł50 the lot?
Old Apr 29, 2012 | 06:51 PM
EscortCookie
I've managed to fix it, the linkage hadnt been put back right :s It's all good now, thanks everyone!
andyrs1600i
Apr 29, 2026 03:21 PM
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
