transit connect immobiliser.
Old Apr 28, 2012 | 07:12 PM
michael harbour's Avatar
michael harbour
Default transit connect immobiliser.
help.... my mate 05 connect as immobilised its self
any ideas ??????????
Old Apr 28, 2012 | 07:19 PM
GVK.'s Avatar
GVK.
Does it crank?
Is there ------ on the dash instead of the mileage?
Old Apr 28, 2012 | 07:27 PM
michael harbour
Originally Posted by GVK.
Does it crank?
no mate just the little red light flashing fast when you put ignition on?
Old Apr 28, 2012 | 07:33 PM
GVK.'s Avatar
GVK.
That normally means the key isn't recognised.
Does he have a spare key to try, or has that already been done?
I had one (diesel) recently that wouldn't start/crank and it was the small black power hold relay (powers up ECU) failed in the underbonnet fusebox. I swapped relay for the one next to it that's marked fuel pump, to try it.
http://ww2.justanswer.com/uploads/s4..._Focus_BJB.jpg
C1403 in this diagram.
Check all the fuses in both fuse boxes too.
Old Apr 28, 2012 | 07:54 PM
michael harbour
spot on mate thats it running. cheers
Old Apr 28, 2012 | 07:58 PM
GVK.'s Avatar
GVK.
Relay?
Old Apr 28, 2012 | 08:14 PM
michael harbour
Relay?
yip cheers
Old Apr 28, 2012 | 08:22 PM
GVK.'s Avatar
GVK.
Sweet! Good guess
Old Dec 5, 2012 | 05:50 PM
milimwshajonti's Avatar
milimwshajonti
hi, i have an 06 transit connect tdci, i have a problem with it in the mornings, does not crank and milage does not display it only shows ------ when this problem occurs. seems only to happen on colder or icy mornings. it will start in the end after few attempts but problem seems to be getting worse!!!
Old Oct 7, 2014 | 05:44 AM
ian50's Avatar
ian50
Default connect
Does it crank?
hi i see you have posted a question about the - -- - - in stead of the mileage i have the same problem and mine does not crank help
Old Oct 7, 2014 | 05:53 PM
milimwshajonti
I had the same problem on the colder mornings, mine is a 56 plate, i understand that the have different fuseboxes on different ages.in the fuse box under the bonnet there is a row of four small black relays,2 for lights 1 for fuel pump and 1 is the power up relay(r8),this was the one that caused the problem for me. Swap it with one of the light ones to try it.this is what i did and its gone ever since!!
Old Oct 7, 2014 | 05:54 PM
milimwshajonti
Let me know how you got on!!
Old Dec 6, 2014 | 01:52 PM
jamieq22's Avatar
jamieq22
Talking -----
I have a 2006 ford transit connect, had the ------ instead of the mileage, the van would not start or even make a sound. I knew it wasn't the battery because all the lights worked and I tried to jump start the van which did not work. After reading on here it could be the relay I changed relay (8) which looks like it has a pump picture on it with one of the lighting ones as suggested by milimwshajonti. It started first time so happy I punched the air, know i don't have to spend stupid money on stupid mechanics. After driving around a few shops I found found a relay for just over Ł5 at whoopee motor factors. (Cheaper than i thought) the only problem know is the code needs to be re entered into the radio and I seem to have lost it.....
Old Sep 24, 2015 | 10:08 PM
Lukebradbury87's Avatar
Lukebradbury87
Default After reading this
After reading this about the immobiliser and not cranking I was jumping for joy and jumped into my car for a trip on what I fort may fix my van 🙈 on arrival van was doing same thing red light blinking not cranking. I done what I read and removed the relay and swapped for another, nothing! Red light stopped blinking but still no crank HELP!!
Old Jan 6, 2017 | 08:22 PM
Enda De Bruin's Avatar
Enda De Bruin
Default Ford Connect wont start after head gasket
Hi
I changed the head gasket and the timing belt and timed the crank and cam up but did not remove the fuel pump. I primed the pump and have fuel coming to the injectors. No issues that i can tell with the immobiliser but it will crank and will not fire even on a tow. Any ideas ?
Old Mar 10, 2019 | 10:36 PM
GC47G's Avatar
GC47G
2008 transit connect , with siemens fuel pump . Won’t crank or turn over , can someone point me in the direction off where to start .
Old Mar 11, 2019 | 04:46 PM
You getting power to the starter motor when trying to crank??
Old Mar 10, 2021 | 08:38 AM
Didier Bidaux Olivera's Avatar
Hello to everyone in the forum! Had the same problem that @MichaelHarbour, and I didn't found why (I`ve checked cluster, wiring and ECU). So, the reply of @GVK. was absolutely effective!
The R8 relay was the problem! I've changed to try, but worked perfectly. I've bought a new relay and finish the job!
Old Mar 10, 2021 | 06:44 PM
GVK.'s Avatar
GVK.
Thanks for posting
Old Nov 13, 2022 | 04:50 PM
beretta687@googlemail.com's Avatar
Default 2003 connect van
Having a night mare with 2003 van after 10 starts it doesn't start. The immobiliser light just flashes constantly, then I have to take it to local mechanic to reset the system
Ive bought an additional key and the same keeps happening. The other day we replaced the body control module Ł400 still not working won’t start again after 10 starts.
please help is there anything I can try ?
Old Nov 13, 2022 | 04:56 PM
GVK.'s Avatar
GVK.
Need to know error codes when its faulting really
Old Nov 13, 2022 | 04:58 PM
Is this counting how many times the red light flashes ?
Old Nov 13, 2022 | 05:06 PM
GVK.'s Avatar
GVK.
No, needs the van scanning for codes in engine ECU, and instrument cluster if applicable.
When your mechanic reset the system there should have been codes set.
Old Nov 13, 2022 | 05:09 PM
GVK.'s Avatar
GVK.
If there is a flash code on the red immo light I can't remember what the codes mean these days. A google may help.
edit - https://www.fordwiki.co.uk/index.php...er_Fault_Codes
https://mhhauto.com/Thread-PATS-SECURITY-FLASH-CODES
Old Nov 14, 2022 | 05:30 PM
Thanks tried taking a look but just can’t figure it out, van is so clean so reluctant to scrap but spent more money on it then I’ve bought it for so scrap yard I think it might be lol
ian50
Oct 23, 2014 06:20 PM
mrtetley
Feb 6, 2010 10:07 PM
tosh
Nov 15, 2009 04:26 PM
dojj
Sep 2, 2008 08:36 AM
