Cosworth 4wd - 2wd conversion.... Exhaust Systems
Old Apr 27, 2012 | 08:36 PM
Mungus's Avatar
Mungus
Default Cosworth 4wd - 2wd conversion.... Exhaust Systems
Now then....
The learning curve just doesnt tail off does it?!
Ok so my car has had a 2wd conversion by the previous keeper.
The exhaust on it was a Scorpian 2WD which through personal preference I changed to a mongoose.
Now I thought (and had been advised accordingly) that the 4wd will fit the 2wd, but not the other way around. So installed my exhaust.... fit is TERRIBLE - fowls the gearbox and causing an awful vibration now
Was I mis informed?! Thinking at this rate, im going to have to change systems again... or have the pipe modded?
Any light?
Huw
Old Apr 29, 2012 | 03:33 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
I am soon (He says lol) changing mine to 2wd and been told by Richie that my 4x4 system will fit fine cause it's technically routed around the front prop/transfer box so shouldn't foul anything.
Old Apr 29, 2012 | 03:56 PM
dakar's Avatar
dakar
sell me your mongoose then
Old Apr 29, 2012 | 04:40 PM
Mungus's Avatar
Mungus
Thats what I have been told and it makes all logical sence that it would.... but not on mine. Im geeting worried that either I have an issue... either with the gearbox or.... the turbo exhaust housing???
Huw
Old Apr 29, 2012 | 09:44 PM
Longshanks's Avatar
Longshanks
Is there any difference in the engine mounts.. I have been told if 2wd is sat on 4wd mounts that it sits slightly higher which causes vibration on front pipe .. How much truth is in this I don't know
May 31, 2016 09:28 PM
Aug 14, 2015 07:29 AM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
