escort rs turbo s2 help
Old Apr 27, 2012 | 05:47 PM
saman's Avatar
saman
Default escort rs turbo s2 help
hi there iv just got my rs turbo on the road i was out in it the other day an i put my foot down in 3rd gear an hit about 80 an the revs droped an i let go of the accelerator an put my foot down again an still in 3rd i now hit 90 and the revs droped again an then let go of the gas an put foot down ok again . can any one tell me wat this could be? thank u peeps.
Old Apr 27, 2012 | 08:59 PM
mgtkr1's Avatar
mgtkr1
sounds like an ignition related issue. are you certain the car is set up and fueling correctly?
Old Apr 27, 2012 | 09:21 PM
gpm89's Avatar
gpm89
Does it feel harsh when the
Revs drop? A weak pipe from metering unit to the turbo can collapse And cause the car to almost cut out
Old Apr 27, 2012 | 09:28 PM
saman's Avatar
saman
cheers bud gunna b getting it setup at jano oddkiddcreations. cud it b the coil?
Old Apr 27, 2012 | 09:37 PM
mgtkr1's Avatar
mgtkr1
could be, what i thought coil or [poss plugsleads, that type of thing. what gpm suggested sounds more feasible though if its a common fault. could be worth investigating pipes/hoses for age/heat related deteriation. jano is the kiddy when it comes to setting the cvh turbo up going on what the clued up types on here reckon.
Old Apr 27, 2012 | 09:41 PM
saman's Avatar
saman
the revs just drop right to the bottom then i just take my foot off then put bk on its ok till i hit 90 its really buggin me this
Old Apr 27, 2012 | 09:43 PM
saman's Avatar
saman
wat pipes i need to look out for?
Old Apr 27, 2012 | 09:45 PM
mgtkr1's Avatar
mgtkr1
boost pipes/vaccum pipes ect
Old Apr 27, 2012 | 09:47 PM
saman's Avatar
saman
thanks guys
Old Apr 29, 2012 | 10:06 AM
gpm89's Avatar
gpm89
If it is the pipe collapsing its the big one that goes from the front inlet on the turbo into the metering unit
Old May 4, 2012 | 07:06 PM
johnnysash's Avatar
johnnysash
Could be overboosting and the chip cutting the spark?
Old May 4, 2012 | 07:26 PM
Mats1985's Avatar
Mats1985
Could b the knock sensor on the inlet
Old May 5, 2012 | 01:31 AM
saman's Avatar
saman
yes it was overboosting 20 psi lol an a air leak thanks to every one who tryed to help
Old May 5, 2012 | 05:49 PM
mgtkr1's Avatar
mgtkr1
so, it was overboosting as a result of the airleak. what amount of boost does the car run in healthy normal circumstances? glad its sorted bud
Old May 5, 2012 | 06:28 PM
saman's Avatar
saman
jano sorted it mate hes a really clued up man knows wat hes on about an he explains every think to ya about wat he is doing to ur car. the boost im running now is around 15psi
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
FlashRS
Sep 14, 2015 12:36 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
