Ford Classics & Vintage Discuss all other Ford cars here, from the classics to Vintage to the Australian and American Fords!
Quick RWD Zetec water pump Q
Old Apr 27, 2012 | 05:44 PM
Antony.'s Avatar
Antony.
Default Quick RWD Zetec water pump Q
I believe that an extra idler can be used to avoid the incorrect of rotation of the water pump on a blacktop zetec when the aircon and PAS has been removed but i want to keep it pretty minimal. So i plan on just putting the alternate water pump in instead...buuuut. Which one is needed? I have also read that the pump only needs changing when a silver top is used so i'm not sure what to believe?
Thanks in advance guys!
Antony.
Old Apr 28, 2012 | 12:11 PM
Antony.'s Avatar
Antony.
Anybody any idea? i have seen pictures of a blacktop zetec on the retro ford website where the cambelt only has one tensioner/idler and the water pump is right in the middle. Looks much better IMO and would love to know how they've managed it!
Old Jun 1, 2012 | 10:33 AM
evans2822's Avatar
evans2822
Its a 1.8 escort type pump you need mate you'll need the ribbed pully to go with It
Old Jul 11, 2012 | 06:43 PM
kawazuki's Avatar
kawazuki
Just been all through this bollux myself so here goes.....There is only one type of Blacktop pump - the silver top has two types depending on the drive belt routing hence you can swop the 1.8 for the 2.0 type. The Silver top cambelt only has one idler / tensioner so allowing the pump impeller to sit directly over the hole in the block.... the Blacktop has two therefore the pump has to be offset to the right towards the exhaust. To obtain a short 1-2-3 point belt run requires a reverse pattern impeller to be fitted or get creative with various idlers!
s1turboman
Aug 29, 2015 04:27 PM
cameron2
Aug 25, 2015 07:18 AM
Dubs44
Aug 21, 2015 02:42 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
