Any one help Underside restoration
My Cossie has been stood for almost a year & although inside its got surface rust underneath. Is there a company out there that can tart this up a bit. Dont need a full resto as its not bad but is annoying.
I would normally do this myself but not sure i will be able to do it any time soon.
Cheers Rod
Cheers Rod
surely you must have a contact that can do this sort of thing Rod?
what about Andy Robinson cars? http://www.robinson-race-cars.co.uk/ he's in your neck of the woods, not sure if he does this sort of thing though
I dont really. For paint i use a company in Reading, this is just a tart up underside. Remember a company on here that did just what i want but it was years ago. Ive always done this sort of thing myself but im struggling with my arm & it may not improve much more im told so arms in air aint going to happen
It can turn in to a mammoth job as i've just started mine thinking it was just a quick clean but once you start digging you find other area's that may as well be done whilst your under there making the job a lot bigger than originally thought.
I've seen work done by COSSIECRAZY the escort Cosworth registrar - he's up in Stoke on trent though but his work seems good, i've seen a few car done by him
https://passionford.com/forum/member...ssiecrazy.html
http://www.escortrscosworth.com/forum/member.php?u=236
.I've gone for schultz underseal as the car is black and the floor is clean and straight so the finish from the gun will be nice enough and everything else powdercoated satin black - not proper concours but preserved for the future
thing is beams and shafts etc will rust becuase they are what takes thehit from stones etc more than the floor does
but if everythigng is done correct then it should last longer than a year but it all depends if its driven in all weathers, if it is then winter time it needs cleaning a lot more regular
maybe a coat of something like wd40 to help protect it from water etc, so once its washed spray on yes it will get dirty but at least you know with a simple wash it will stillcome up like new again
its worth just doing it fully once and doing it rite as id imagine you know,then its just down to general maintenance and a clean ad keeping ontop of it, as if its not kept it will just go back to how it was
I had a bad experience there many years ago just after i got my saff he did my rear arch less than a week after it started to bubble up so he did it again and the same happened again so he told me theres nothing he can do its an old car lol i told him id not let him do it again anyway! (i had it re done at moonface in hook) The best ive seen round are way is the russel brothers in andover they did my mate sys rs turbo but it did cost a lot of money but at the end of the day with paint if you pay cheap you get a cheap job
SMILER258
Sep 28, 2015 09:04 AM
