Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
mk1 Focus rear caliper removal/swap...
Old Apr 25, 2012 | 07:41 PM
Camel Fiddler's Avatar
Camel Fiddler
Resident Camel Stalker
Default mk1 Focus rear caliper removal/swap...
I know this is going to be such a noob question but...
Can anyone explain how to remove a rear caliper? My handbrake isn't engaging properly on the nearside. There is a new cable fitted but it's still below MOT standard. I have notice there is a hook on the caliper that the cable hooks onto that moves on the o/s by about 90degrees as the handbrake engages and disengages. The nearside one doesn't seem to move. It feels stiff compared to the n/s so am thinking it's an issue with the caliper itself. So, how is the caliper removed completely so I can change it? Step by step would be ideal
Old Apr 25, 2012 | 07:47 PM
RichieST's Avatar
RichieST
Just 2 bolts on the back and it comes off. Don't forget to clamp the brake hose before removing that too.
Old Apr 25, 2012 | 08:04 PM
Camel Fiddler
Yeah am not that silly lol well maybe.......
Any pics of the position of the bolts? Just want to get it done nice n easy without hassle.
Old Apr 26, 2012 | 07:52 PM
Greasenuts's Avatar
Greasenuts
if memory serves me right there hidden under 2 little black caps and are undone using a 7mm allen key!
also it does sound like your on the right track by replacing the caliper!
Old Apr 27, 2012 | 10:09 AM
Straight_4_N/a's Avatar
Straight_4_N/a
ive got a spare rear caipler in my house that i can take some pics of to show you where the bolts are.
in total theres 4 bolts, 2 hold the caipler to the caipler holder and 2 hold the caipler holder to the hub. if your getting one from the scrap yard you have to undo the two that hold the caipler holder to the hub but if your getting a recon caipler you need to undo the first two that hold the caipler to the caipler holder.
quick step by step
1 first you'll want to get a set of mole grips on the brake line.
2 then you want to undo the brake line from the caipler just abit to get it lose.
3 then undo the top two bolts.
4 then pull the caipler up and push towards the car.
5 then with the caipler off disc push it towards the front of the car and lift the cable of the caipler and then twist the caipler around to get the brake line off.
refitting is just the reverse of the above starting with the brake line then handbrake cable then fitting the caipler back on. [Note] if your buying a second hand caipler from the scrap yard then dont forget to wind the piston back in.
Old Apr 27, 2012 | 03:45 PM
Camel Fiddler
Cheers to those who helped car passed the mot
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
FlashRS
Sep 14, 2015 12:36 PM
james kiely
Aug 28, 2015 08:58 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
track.focus'd
Aug 12, 2015 05:53 PM
