RST bits and ZT parts
Skint Passionford User
FRS Stat housing with New bolts, bought off JPA on here but I've decided to use a CVH item £25 posted
forgot to take a pic! Looks like every other blacktop stat housing but without tge sensor on top
FRST Charge Carrier £25 posted
ERST Charge carrier £25 posted
RST Exhaust Manifold £30 posted
RST Exhaust manifold to ZETEC flange adaptor £30 posted
2WD cos engine loom, needs the coil parts re-terminating as I had a wasted spark loom on it,but thats gone SOLD
PM or text me please and I'm in work all the feckin time so cant really speak on the phone
07776233582
More bits and pics to be added shortly....
07776233582
The looms off my old 2wd saff, ran fine with no electrical gremlins. Could do with tidying up a little but but it all worked fine. The parts that run to the coil have had the connectors chopped off and the loom taped up,but if you re-terminate it, it'll be reet
PM replied Stu
It uses cap headed bolts to bolt to the head. the studs are countersunk on the other side.
Comes with all nuts/bolts/washers etc. Just needs gaskets to fit it up.
Billy_RS
16
Oct 11, 2025 09:41 PM
