Ford KA Discuss your Ford KA here!
ka rst help needed
Old Apr 24, 2012 | 10:41 PM
steve_o's Avatar
steve_o
Default ka rst help needed
hi guys, got a ka with a fiesta rst engine fitted running on ofac management, but wont start, i have got spark, and fuel getting up to the rail but no further, just wondered what i shud be getting at the injector multi plugs to switch the injectors on, with ignition off both pins on the multi plugs are earth, igntion on they both turn live, when cranked one pulses live and the other pin stays live, what shud i be getting here? any help wud be greatly appreciated, cheers.
Old Apr 25, 2012 | 07:10 AM
oldford's Avatar
oldford
This exactly what you should be getting.
The reason both pins have 12 volt with ignition on is the following:
1 pin is the feed, it always has 12 volt on it. The other is switched by the ecu.
To define the signal and minimize noise a pull-up resistor to 12 volt is used.
When 1 pin pulses during cranking fuel is injected.
Try starting with a disconnected catalyst. Will make a lot of noise!
Old Apr 25, 2012 | 06:07 PM
1980blakey's Avatar
1980blakey
Check all the earths for the engine loom, Had exactly the same in my ka when i changed from zvh to zetec turbo and i had missed the earth near the amal valve.
Old Apr 25, 2012 | 10:15 PM
steve_o's Avatar
steve_o
ok will do, cheers guys, much appreciated!
Billy_RS
16
Oct 11, 2025 09:41 PM
Chas
Sep 21, 2015 08:57 PM
A.t.p
Aug 15, 2015 11:37 AM
col93saphcos
Aug 7, 2015 03:21 PM
dlwarrior
Aug 5, 2015 10:19 AM
