Sierra Cosworth gearbox?
I have a little problem finding gearbox for my Cossie here in iceland, so i was going to ask if some genius here know if i can use a T5 gearbox from V6 Camaro '93model for my sierra 2wd without any trouble.
It will probably phyically bolt up with the Cossie bell housing but you might find it has different gear ratios probably taller ones if it from a V8.
Have you got the box part number?
Edited to say it might have a different input shaft too you'll need to check the splines.
Rich
Rich
So this camaro box may have diffrent splines on the input shaft but does anyone know if the input shaft is longer or shorter in the camaro box?.. if its the same length i may be able to mix the clutch a little, use clutch for camaro and clutch pressure plate from ford
charliecosworth
19-08-2015 02:00 PM
155lee
14-08-2015 11:21 AM
