Big brake conversion
Old Apr 23, 2012 | 03:35 PM
Skinny's Avatar
Skinny
Default Big brake conversion
I'm looking at uprating my front brakes, I've been looking at doing the 300mm conversion using the Mk3 Mondeo front calipers with the focus st170 disks. I was just wondering if any of you had already done this and what it is like if so?
Old Apr 23, 2012 | 04:02 PM
Chopshop85's Avatar
Chopshop85
Just done this recently.
You get a bite more bite under braking. Its not neck braking, but it is noticeable. Nice easy conversion as well, providing you are not running std rst wheels.
Old Apr 23, 2012 | 04:07 PM
zippyobrien's Avatar
zippyobrien
Grind em down a bit and they will fit under standard rims.
Old Apr 23, 2012 | 05:10 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Been running this for a couple of years now and it's a big improvement, a MC and servo from a MK3 Mondeo will sharpen them up even more.
Old Apr 23, 2012 | 05:18 PM
phil_rs's Avatar
phil_rs
yam yammer
Or better still..... one from a Sport Ka
Old Apr 23, 2012 | 05:21 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Why is that better mate?
Old Apr 23, 2012 | 05:29 PM
phil_rs's Avatar
phil_rs
yam yammer
Larger MS bore size mate
Old Apr 23, 2012 | 05:42 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Oh! Do you know what size they actually are (Ka and Mondeo)? Cheers!
Old Apr 23, 2012 | 05:49 PM
phil_rs's Avatar
phil_rs
yam yammer
I'll try and find out but if you already have the mondeo one, it won't be worth the effort upgrading to the ka one.
Old Apr 23, 2012 | 06:39 PM
shalon's Avatar
shalon
i have a set of mondeo calipers if youre interested mate
Old Apr 23, 2012 | 07:28 PM
Skinny's Avatar
Skinny
How much you after for them mate?
Old Oct 28, 2013 | 05:11 PM
RS-adam's Avatar
RS-adam
I was just wondering... Is the mondeo mk.3 calipers and carriers a stright fit to the rs turbo, when using the fokus st170 discs?
Old Oct 31, 2013 | 10:59 PM
zippyobrien
Need a spacer between the Hub and caliper
Old Feb 22, 2015 | 04:25 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Is the sport ka servo conversion easy to do on the series 2?
Old Feb 22, 2015 | 09:05 PM
makaveli96's Avatar
makaveli96
I think I need to upgrade my MC and servo I've already removed my abs will the 1.6 Ka still be ok to upgrade from?
Old Apr 8, 2015 | 09:24 AM
Gem frst's Avatar
Gem frst
Is the ka or mk3 mondeo servo and ms a bolt on part part or do you have to modify anything to get it to fit
yatta
May 21, 2016 10:31 PM
IainRS1700T
Sep 25, 2015 06:44 AM
wattie
Sep 16, 2015 11:34 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
