yes or no
Old Apr 23, 2012 | 02:43 PM
chrismjones's Avatar
chrismjones
Question yes or no
hi i have a sapph cossie i changed the oil in it just before it went away 6 months ago for winter and it hasnnt been driven since.The oil is still golden but will it still be ok might be a strange question but someone told me to change it again what do you guys recommend
Old Apr 23, 2012 | 02:54 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
will be fine
Old Apr 23, 2012 | 03:19 PM
chrismjones
Question
cheers mate.it seems to have developed another problem while its been sat still when you turn full lock one way and start to turn the other it feels like its grinding acroos something you can feel it throught the wheel.like you get back to centre then it twangs/pings
Old Apr 23, 2012 | 04:08 PM
rs2klee's Avatar
rs2klee
K***LMT
check the power steering fluid level.. or replace it might have condensation in the steering fluid? id drain it all out top up with new fluid.. jack it up just to take the weight off the wheels dont need it too high, start the engine, then turn left to right slowly from lock to lock. See if its made any difference!.
