brake callipers, help please
Old Apr 22, 2012 | 10:46 AM
dirtysteve's Avatar
dirtysteve
Default brake callipers, help please
my mate had the front brakes from my 90 spec abs rst for his non abs cabriolet, but we cant get any decent braking at all, bloody awfull if anything, can anyone think of a reason?, are abs callipers compatable??, any help would be appreciated, cheers, steve
Old Apr 22, 2012 | 10:51 AM
studabear's Avatar
studabear
yeah they are compatible.
please define bloody awful
Old Apr 22, 2012 | 11:06 AM
dirtysteve's Avatar
dirtysteve
you'd probably stop better dragging a bit of wood out of the window!!, we've renewed the master cylinder but no better, blead it loads, but still no change, the master cylinder has 4 outlets wheras the turbo had 2, i just wondered if this would make a difference, also someone mentioned "had he got the boosters from the turbo"???, mean anything?
Old Apr 22, 2012 | 12:20 PM
studabear's Avatar
studabear
is the pedal pressure poor ?
Old Apr 22, 2012 | 02:00 PM
dirtysteve's Avatar
dirtysteve
the pedal feels o.k, but pressure on the pedal doesnt seem to transmit to the brakes if that makes any sense
Old Apr 22, 2012 | 03:13 PM
studabear's Avatar
studabear
are the brake pads and discs new? have they bedded in properly?
Old Apr 22, 2012 | 06:58 PM
johnnysash's Avatar
johnnysash
Is the master cylinder bore a different size between the cars you changed them between. Also I would check rear cylinders. They may have gave up when you was bleeding the lines
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
