paddle clutch
Old Apr 21, 2012 | 09:22 AM
wedge07's Avatar
wedge07
Default paddle clutch
Hi i am going to be taking my engine out soon to paint my engine bay and block. So i thought then is a good time to whack a 4 paddle clutch in whilest its on engine hoist so which make n where is best place to get one from? Im running efi by the way on erst lsd box
Old Apr 21, 2012 | 11:05 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Unless you need a paddle I would not recommend one, judder/vibrate when pulling away etc. making town driving a real chore due to their on/off nature and do not last many miles compared to a normal clutch either.
AP's organic range (CP2000-8 and -35) will cope with roughly 230bhp/ftlb and 300bhp/ftlb respectively and are what I would recommend mate
Old Apr 21, 2012 | 11:42 AM
wedge07's Avatar
wedge07
when i pull away from stopped it has a bit of a judder as it is now, i never checked clutch when i put engine in so maybe i already have one lol cheers mate what sort of price is an ap organic?
Old Apr 21, 2012 | 11:49 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Could be, flywheel might not of been slimmed when it was fitted either?
They are not cheap, IIRC Ł300 and Ł400 repectively! I've had both (currently the -35) and they are well worth the money specially as I hate the feel of a paddle for daily driving.
Old Apr 21, 2012 | 12:07 PM
matthart's Avatar
matthart
You don't get a "bit of judder" with a paddle, you KNOW when one is fitted lol
I would also suggest against getting a paddle unless you only drive it rarely.
I've got one and I'm just getting used to it! You really can bang through the gears when you get it right, but you look a right plank when you get it wrong, and I often do...
I went for a paddle because I'm hoping I've future-proofed it for when the boost goes up
Old Apr 21, 2012 | 02:43 PM
darrenb16two's Avatar
darrenb16two
Didnt realise you could get organic clutches that could take 300bhp ! Is the pedal really hard?
Old Apr 21, 2012 | 02:58 PM
gus's Avatar
gus
on / off nature with a paddle
jeeez you should try and drive mine
im use to it now but my god its harsh
Old Apr 21, 2012 | 03:23 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes and yes! lol The reason I went hydraulic
Old Apr 22, 2012 | 03:00 PM
wedge07's Avatar
wedge07
Ill get an organic one then i think, my sort of snaps from pulling off if u get me?
Old Apr 22, 2012 | 04:01 PM
mk1trb's Avatar
mk1trb
Boost Junkie
i had a paddle with a standard pressure plate and was fine to use everyday, drove like a normal clutch did. problem is they eat flywheels
Old Apr 22, 2012 | 04:04 PM
darrenb16two
Sounds like you'll have to mod the pedal or go hydrulic though mate
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
