mot question
Yes they will fail it,
If you remove the pump and fluid then the rack will more than likely have play in it.
As above just fix it
its the safest thing to do.
Are they not electric power steering on those like the saxos? If so the saxos suffer from a wiring problem within the ignition cowling or even sometimes the alternator
This or also check as the ignition barrel is returning to the correct point after starting.It will stop the steering from working correctly.
correct it is electric power steering and not belt driven
i had a read up and it seems a common problrm
i smacked it with a hammer and it is all working again
when in doubt give it a clout
