help plz
Old Apr 19, 2012 | 08:48 PM
saman's Avatar
saman
Default help plz
hi there peeps just need a bit of help iv just had the head gasket done an skimmed now iv got the rs bk the temp is high at the top just under the red but the fan kicks in an stays on? i spoke to my mechanic an he said every think is good an the temp gauge might be faulty? plz someone help really stressed out.cheers.
Old Apr 20, 2012 | 09:36 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
Have you check for air locks?
Old Apr 21, 2012 | 11:15 AM
saman's Avatar
saman
how do u check for air locks?
Old Apr 21, 2012 | 11:19 AM
saman's Avatar
saman
and my car heaters in side the car have stoped workin?
Old Apr 21, 2012 | 11:20 AM
Mark_'s Avatar
Mark_
Sounds like an air lock if the heaters are not working aswell.
Is there water returning to the header tank?
Old Apr 21, 2012 | 11:40 AM
Karlos G's Avatar
Karlos G
Balls Deep!
If the fans stay on and they didnt before as well as the gauge now sitting just under the red then you are hot for sure.
Heaters blowing cold air of not blowing at all?
I've never had a air lock on a CVH coolant system but with the engine running and header tank cap off go around squeezing all your coolant hoses, also if some feel hot and other cold then the water is not getting to the cold ones, ergo there may be an air lock.
Old Apr 21, 2012 | 12:36 PM
saman's Avatar
saman
cheers guys ill have a look an let u guys no thanks
Old Apr 21, 2012 | 02:46 PM
saman's Avatar
saman
heaters are not blowing air at all?
Old Apr 21, 2012 | 03:25 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If thats the case it has nothing to do with the coolant system, thats a separate electrical fault.
Old Apr 21, 2012 | 11:22 PM
saman's Avatar
saman
all the pipes are hot the same but the temp is in norm at the top N but iv only got 1 slim line fan on the rad could that b the problem an the fan is kickin in late an thats all happening on tick over.
Old Apr 21, 2012 | 11:38 PM
saman's Avatar
saman
and the fans are stayin on?
Old Apr 22, 2012 | 12:08 AM
PhilCook's Avatar
PhilCook
Get a low temp stat
Old Apr 22, 2012 | 09:55 AM
saman's Avatar
saman
chers guys i will try the low temp stat. about my heaters inside my car not working? what cud it be? iv changed the heater blower under the bonnet still not working?
rsturbo27
Sep 1, 2015 09:54 PM
niallturbo
Dec 21, 2004 08:14 PM
cossieanth
Nov 21, 2004 06:54 PM
11
Mar 13, 2004 09:11 AM
28
Dec 10, 2003 07:46 PM
