Understanding 1/4 mile times
Old Apr 18, 2012 | 06:01 PM
jonesymk2's Avatar
jonesymk2
Default Understanding 1/4 mile times
I did 3 runs at central day in my estate,my 1st run I manged a 13.2 at 100.38mph and 60ft time was 1.894,my 2nd run was 13.4 at 104.78mph and 60ft time was 1.906 and then my 3rd run was 13.7 at 107.55mph and 60ft time was 2.220,what Im struggleing to work out is how my quickest run time wise was slowest speed wise,sorry if its a thick question
Old Apr 18, 2012 | 06:07 PM
TOOTALL's Avatar
TOOTALL
The 60ft time?
Old Apr 18, 2012 | 06:09 PM
Luca's Avatar
Luca
Lukesville
Its all to do with you have longer time to gain those extra speeds.
The better the launch the better the car is gripping and thus getting you to the 1/4mile line in a quicker time but not generating a quicker speed because you get there quicker.
If that makes any sense at all?
Old Apr 18, 2012 | 06:10 PM
jonesymk2's Avatar
jonesymk2
I did think that but surely the quickest 60ft time I should have got a faster terminal speed aswell :-/
Old Apr 18, 2012 | 06:12 PM
jonesymk2's Avatar
jonesymk2
Ok cool that makes sense after reading it a couple of times lol cheers
Old Apr 18, 2012 | 06:13 PM
Luca's Avatar
Luca
Lukesville
it still confuses me to be honest
Old Apr 18, 2012 | 06:22 PM
jonesymk2's Avatar
jonesymk2
My 1st run I changed into 5th gear just before the finish line but the other 2 runs I held it in 4th so didn't know if the terminal speeds were to do with that aswell :-/ I can never really get my head round it properly :-/
Old Apr 18, 2012 | 06:34 PM
WongRS's Avatar
WongRS
It's all about 60ft's really, my 12.4 was a 1.6 60 ft, but only doing 108 mph, i'd done 114 mph on a previous run but with a 1.8 60ft and 12.7 run.
I don't fully understand either, to be honest.
Old Apr 18, 2012 | 07:02 PM
jonesymk2's Avatar
jonesymk2
The more I think about it it makes a bit more sense but not much more lol
Old Apr 18, 2012 | 07:08 PM
Karl's Avatar
Karl
Norris Motorsport
Assuming you don't fluff any gear changes, and the run is otherwise identical your fastest actual time will be the run with the fastest 60ft time.
The faster you are doing at the 60ft mark, again assuming you dont fluff any gears and use the same gears (i.e. not changing into 5th) the faster you will cross the line because you are carrying more speed at the 60ft mark with a fixed amount of distance left to accelerate in. For that given distance if you are starting at a higher speed you will end up with a higher terminal speed.
As a very rough ball park we find that ever 0.1 saved on the 60ft time will save you 0.2 secs overall but obviously that is assuming each run is identical other than the 60ft time.
Changing gear just before the finish line is a complete no no! If you can hang onto 4th gear then do so, even if your power is tailing. It will give a quicker time.
Lastly remember your terminal speed is only the average speed over the last 60 ft of the run, not the actual terminal speed. For most cars that are'nt accelerating much at 100mph that won't differ much, but on hugh bhp cars it's a suprising difference. (up to 5mph more at the finish line compared to the 60ft average).
Hope that helps folk understand the drag strip a little more.
Old Apr 18, 2012 | 07:11 PM
RSGARETHW's Avatar
RSGARETHW
always working
great reply, always wondered myself...
Old Apr 18, 2012 | 07:23 PM
jonesymk2's Avatar
jonesymk2
That's a great help cheers makes understanding it a bit easier I will be running the car again at classic ford show hopefully so will try and improve on my times a bit more,central day was only the 2nd time I had taken the car up the strip so still room for some improvement from me with getting it off the line and everything else involved
Old Apr 18, 2012 | 07:32 PM
Luca's Avatar
Luca
Lukesville
A little better to understand now.
Drag slick time!
Old Apr 18, 2012 | 07:36 PM
Beach's Avatar
Beach
Are you the bloke with the estate running the yb?
Old Apr 18, 2012 | 07:51 PM
jonesymk2's Avatar
jonesymk2
Yes mate
Old Apr 18, 2012 | 08:02 PM
WongRS's Avatar
WongRS
Excellent reply from Karl there!
Old Apr 18, 2012 | 08:33 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I didn't know the terminal speed was a average over the last 60ft
Steve
Old Apr 18, 2012 | 09:26 PM
Dlatch!'s Avatar
Dlatch!
repeat your best 60 ft time and hold it in 4th and you will better your time for sure
it is all won or lost in the first 60ft as that is where the traction is hardest to find and 0.10 sec gained there really make a difference come the finish
Old Apr 18, 2012 | 09:31 PM
jonesymk2's Avatar
jonesymk2
My estate is 4wd so traction off the line shouldn't be a problem hopefully,my 3rd run I caught the revs wrong and it bogged down so just need to practice a bit more
Old Apr 18, 2012 | 09:46 PM
STAFFY OWNER's Avatar
STAFFY OWNER
Steve
Me neither, i always thought it was the speed that you crossed the line at. Cheers Karl, you learn something new everyday .
Old Apr 18, 2012 | 10:53 PM
jonesymk2's Avatar
jonesymk2
Same here aswell
Old Apr 19, 2012 | 06:40 AM
Beach's Avatar
Beach
Yes mate
You have inspired me to try and buy my mates mk4 abondoned turbo van project complete with NMS engine, whip that into the RS turbo and drop a yb in the van
Me and my mate where nicely suprised when we saw under the bonnet
Old Apr 19, 2012 | 08:18 AM
graham c's Avatar
graham c
i never under stood it either by my 60ft are 20-2.2 @108-111 so need to learn to launch hard
Old Apr 19, 2012 | 09:14 AM
jonesymk2's Avatar
jonesymk2
I was holding the revs at about 4000 and then getting off the clutch as quick as possible and manage just below 1.9 for the 60ft and just over 1.9 on my 2nd run,my 3rd run it bogged down off the line so done a 2.2
Old Apr 19, 2012 | 09:15 AM
jonesymk2's Avatar
jonesymk2
Cheers mate,you will have to put up a thread in the project room if you manage to get it sorted
Old Apr 19, 2012 | 09:32 AM
Beach's Avatar
Beach
Yes it all depends how much he wants for it tbh, its got all the stuff i need for my RS turbo so im telling myself its worth it regardless
Just think a YB'd van would be fun, 4x4 or rwd is the question ?
Its a winter project if i can get a few quid saved up
Old Apr 19, 2012 | 09:50 AM
graham c's Avatar
graham c
skyline box it and you can have both
Old Apr 19, 2012 | 09:59 AM
XRT_si's Avatar
XRT_si
That's really interesting, and of course, makes sense when you think about it.
Old Apr 19, 2012 | 11:44 AM
Beach's Avatar
Beach
Now were talking
Old Apr 19, 2012 | 12:00 PM
Danster76's Avatar
Danster76
Didn't know this either.
Would be smart if this sort of info and 'drag tips' were printed on banners and attached to the barriers on the fire up lane, wouldn't have to cost anything if they got them branded up and so roundabout way, paid for...
Old Apr 19, 2012 | 12:01 PM
jonesymk2's Avatar
jonesymk2
I want to get started on mine soon once I manage to get my Combi van on the road lol then still got my white estate to do something with lol
Old Apr 19, 2012 | 12:08 PM
jonesymk2's Avatar
jonesymk2
Personally I did mine 4wd as there is hardly any weight at the back so would always be eating rear tyres,I will be going with a skyline box sometime soon for the extra peace of mind for the strength
Old Apr 19, 2012 | 12:17 PM
Beach's Avatar
Beach
My thoughts exactly pal the van would be even lighter id imagine with zero interior.
Its your bloody estates fault
Too many projects not enough cashflow hahaha+
Old Apr 19, 2012 | 12:24 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
While I totally understand what Karl is saying there, and my own stab at the theory would say exactly the same, my experience suggests that a worse 60ft on a turbo car (especially a big turbo) often leads to a higher terminal speed, as per the thread starters results.
A friend of mine has an 11 seconds viva that he has a massive amount of data with and there is a massively strong correlation for him between higher 60fts and higher terminals.
Can only assume its due to spool time on the turbo, as I can think of no other reason for the effect that would make any sense.
Ie Karls assumption that a worse 60ft time means you are going slowing at the 60ft isnt always correct, if you go very slowly for the first 30ft and during that time the turbo spools well it will accelerate better for the next 30ft so although you have taken longer to get to 60ft you have done so at either the same or a higher speed and with the turbo spinning faster at the time.
Old Apr 19, 2012 | 03:14 PM
graham c's Avatar
graham c
jonesy my box is in just started building engine now
Old Apr 19, 2012 | 04:12 PM
jonesymk2's Avatar
jonesymk2
I had to do the headgasket on mine last week and had a nightmare all day Saturday and finally got it all sorted and home at 22:30 ready for Sunday so I could take it up the strip lol hopefully I will be able to start saving for the skyline box in the next few months,so it might be a winter project to do the box unless mine gives up the ghost before lol will you be at classic ford show looking around atall
Old Apr 19, 2012 | 04:14 PM
jonesymk2's Avatar
jonesymk2
Yeh know that feeling mate I've got 3 cars all together lol
Old Apr 19, 2012 | 04:25 PM
stevieturbo's Avatar
stevieturbo
C**t
Quite true
Often a faster ET will yield a lower trap speed.
But even a shitty run with a slow ET on the same car can yield a good trap speed.
It almost makes sense when you think about it, then it doesnt.
But trap speeds usually vary less unless the run is a total fuck up, and trap speeds are a good indicator of power.
ET's are largely down to traction first and then power.
Old Apr 19, 2012 | 04:30 PM
stevieturbo
C**t
I think a lot of it is simply that the more traction you have, you cover that ground so much faster in terms of time. So you also cross the line in less time so have had less chance to attain speed. It's certainly not that you've went slower.
As Luca said, you're speed vs time will remain similar, but distance vs time is greatly affected by getting good traction at the start.
Most times Ive run, the 0.1s 60ft gains you 0.2s at the top end is usually pretty damn close ( again assuming a similarly good run )
Old Apr 19, 2012 | 05:37 PM
WongRS's Avatar
WongRS
It's all about 6k side stepping on standard transmission
