cossie inner wings/strut tops different to other sierras?
Old Apr 18, 2012 | 10:41 AM
The Youth.'s Avatar
The Youth.
Default cossie inner wings/strut tops different to other sierras?
I tried last night to fit a strut brave to my xr4x4 race car and it's about an inch too long
tried it on another xr4x4 and it's exactly the same!
I have a pic of the very strut brace I have bought fitted to a cossie so I know it fits a sierra somehow!!!
before I cut carve it and weld it up is there anything Im missing here?
steve
Old Apr 18, 2012 | 11:02 AM
xr4x4rs's Avatar
xr4x4rs
no mate
all the same, ive had it before where ive had to porta power the struts to get strut brace on lol
try it on your escort first, s its unliely these will move becuasethey have th strenghtening braces welded on the strut tops where sierras dont
Old Apr 18, 2012 | 11:23 AM
The Youth.'s Avatar
The Youth.
good idea m8, will try it on my escort tonight,
was suprised it didn't fit specially as the other sierra I tried it on it was out exactly the same amount!
steve
Old Apr 18, 2012 | 01:38 PM
markk's Avatar
markk
very common that for the inner wings to come inwards on a sierra
Old Apr 18, 2012 | 01:57 PM
craig2016's Avatar
craig2016
jack the car up off the ground when trying.
Old Apr 18, 2012 | 06:38 PM
whizzisat114's Avatar
whizzisat114
40" centre to centre iirc
Old Apr 18, 2012 | 07:50 PM
The Youth.'s Avatar
The Youth.
ragging it round a track for 7 years probably hasn't helped!!
craig I tried the trick of jacking it up, it did nothing lol
cheers m8 will check it
I tried the brace on my escort tonight and it's fitted perfectly!
looks like my race cars a bit on the piss lol
is there anything I can do short of cutting the brace down?
might also brace the strut top to the inner wing escort cos style
steve
Old Apr 18, 2012 | 07:52 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
the struts coming in an inch cant be good!!
:shock:
blimey
Old Apr 18, 2012 | 08:12 PM
The Youth.'s Avatar
The Youth.
a quick pic to show how far it's out
steve
Old Apr 18, 2012 | 08:50 PM
cozzy jeff's Avatar
cozzy jeff
have you tried spinning the bar around,mine only fits one way.
Old Apr 18, 2012 | 09:46 PM
Karl's Avatar
Karl
Norris Motorsport
Very common to see sierra strut tops at least an inch closer together than std! The strut tops are very weak, and you'll notice the inner wing below the wing hanging rails will now be curved inwards rather than being vertical!
The Youth.'s Avatar
The Youth.
yea it's actually meant to be the other way round but I tried that and it's still won't fit
I might use some ratchet straps to pull them out then weld a brace to the inner wing!
Will have a look Karl and see if it's as you say but it's looking that way..
steve
Old Apr 19, 2012 | 09:03 AM
xr4x4rs's Avatar
xr4x4rs
get hold of a porta power if you can and push the struts apart
be wise to weld braces like the escos has, thats why i said test it on the escort
the jacking up doesnt usually work as the subframe still holds it all together
Old Apr 24, 2012 | 01:09 PM
The Youth.'s Avatar
The Youth.
bought a 4 ton porta power at the weekend and it worked a treat.
got the strut brace on, just need to weld in the braces I made up to match the ones on my esc cos
steve
Old Apr 25, 2012 | 08:09 AM
vaughant's Avatar
vaughant
Should tighten things up nice now mate!!!
Old Apr 25, 2012 | 11:00 AM
xr4x4rs's Avatar
xr4x4rs
steve
im sure there is a company that actually do the plates ready to be welded in, i just carnt think of the name at the minute, possible rally design maybe
Old Apr 25, 2012 | 11:24 AM
The Youth.'s Avatar
The Youth.
possibly but I made some up the other night, metal fab is something im quite good at after rebuilding my 100E all those years ago lol
vaughant, yes it does seem to have tightened the front up on the short test drive I had.
steve
Old Apr 26, 2012 | 01:34 AM
xr4x4rs's Avatar
xr4x4rs
what id say at alater date, if a philloy brace comes up for sale get that, becuase there a lot better design as they push against the strut not on top
but every little helps
Old Apr 26, 2012 | 02:00 AM
mk22door's Avatar
mk22door
Fart of the Purniture
Just measured my XR4x4 and it's 39 inch and 3/8's
The previous owner had ragged it about a bit, and it is 22 years young.
Going to check my Saff when I get up.
Oct 9, 2015 07:38 PM
Vincereese
Aug 15, 2015 06:24 PM
RsS2daz
Aug 14, 2015 05:26 AM
dal3door
Aug 13, 2015 06:55 AM
Vincereese
Aug 11, 2015 08:44 AM
