dellorto 48 set up
dellorto 48 set up
i have a mk2 rs running twin 48 dellorto ,with fr32 cam.
what would be the correct set up for the carbs,emulsion tubes,main jets,and idle jets,
this is a road going car,any advice would be appreciated.thanks
I have used Dave Andrews guide a few times with great sucess...last kit car I tuned on carbs was modifed using his guide and made lovely power right though the rev range....
http://www.s262612653.websitehome.co...s/dellorto.htm
Twin 48's on a 2 ltr pinto I assume? does sound a little large so you might find it a little lacking in effciency...
HTH
Ian
HTH
Ian
