Fuel system on a zetec with throttle bodies
After opinions on the proposed spec of my new fuel system.
Im looking to run -8 feed from the swirl pot to the filter, -6 for everything else.
Im not sure if the cosworth in tank pump will be overkill for what i'm running though, or if it needs changing for a lift pump or a lower pressure standard item?
I will be running 200bhp+ on my new throttle bodies, and going up to a 75bhp shot of nitrous.
ginner
13
Aug 30, 2015 08:40 AM
