chip info required
Old Feb 27, 2005 | 08:51 PM
the strut brace's Avatar
the strut brace
Default chip info required
will a stg 3 chip from stu work on a g reg 4x4 saff if it was bought for a j reg 4x4 saff, the g reg does not have the lamda sensor and the chip was bought for the j reg one which does have a lambda sensor, the j reg was written off and the g reg one has been bought to replace it, so can the chip go into the g reg one????
Old Feb 27, 2005 | 09:15 PM
Stu @ M Developments's Avatar
PassionFords Creator
Oh no... you havent written your new J reg one off?
Old Feb 27, 2005 | 09:17 PM
Oh,
And send me the serial number off the label and il bring up the map and tell you exactly what it can work in
Old Feb 27, 2005 | 09:18 PM
SPADGE's Avatar
SPADGE
Can't you just swop the ecu's over as well?
Old Feb 27, 2005 | 09:20 PM
Ecu's are the same Spadge, its lambda input thats different, and may be a mute point if its not lambda enabled software.
Ginge !'s Avatar
Ginge !
just finding my feet
i hope ya aint wrote it off mate
Old Feb 27, 2005 | 09:23 PM
SPADGE's Avatar
SPADGE
I thought the ecu's were different Stu? Both L8's but one pre-lambda one post Would the post lambda ecu not function correctly without a sensor then???
Old Feb 27, 2005 | 09:34 PM
Nope. L8s are both the same.
The green label indicated that lambda software was installed within it.
I do closed loop conversions to suit any L8, so i know this for a fact, regardless of the 15yrs worth of myths and alternate pricing structures im afraid it shatters
Old Feb 27, 2005 | 09:35 PM
Rs Gus's Avatar
Rs Gus
impreza wrx sti version 8
you not smashed her have you carl
Old Feb 27, 2005 | 09:36 PM
SPADGE's Avatar
SPADGE
Cool i have learned something then
Cheers Stu
Old Feb 27, 2005 | 09:45 PM
the strut brace
lol, no i havnt its my mates car, the silver 4x4 you did a conversion on stu about 3-4 months ago, he wrote it off shortly after you did it he has his payout and has just bought his new one from paul at nyrs spares tonight
mines never moved for 3 month
Old Feb 27, 2005 | 09:47 PM
Rs Gus's Avatar
Rs Gus
Cheers Stu
l8's going up in price at the emporium now spadge
Old Feb 27, 2005 | 09:49 PM
SPADGE's Avatar
SPADGE
Cheers Stu
Only in line with my current out-goings Gus
Rs Gus's Avatar
Rs Gus
Cheers Stu
