Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
ST 225 Owners
Old Apr 16, 2012 | 09:07 PM
LIMITLESS's Avatar
LIMITLESS
Default ST 225 Owners
What Performance products are you using on your car ?
Looking to be owning my st very soon and need to know whats proven and whats shite
Old Apr 17, 2012 | 06:42 PM
thebigmacmoomin's Avatar
thebigmacmoomin
I am using a K&N panel filter, Dreamscience re-map (DSci map) & an Airtec Gen3 intercooler. Want a sports cat next but will have to look into what one.
Old Apr 17, 2012 | 07:07 PM
duncans90's Avatar
duncans90
Mine is running an Airtec Gen 3 intercooler, Mongoose 3" exhaust system, Dreamscience induction with RS Injectors fitted. Running a custom map at 300.4bhp and 361l/ft torque
Old Apr 17, 2012 | 07:30 PM
Carlos-Titx's Avatar
Carlos-Titx
J&R panel filter, RS clutch kit, Decat, Scorpion cat back, Colins Dump Valve, Dreamscience Platform with DSCi map. Circa 275 bhp (not proven)
See a lot at the moment with REVO remaps, meant to be really good and have the bonus of various maps, one of which the car wont rev over 2k if your car is at a garage or something similar.
Old Apr 17, 2012 | 07:49 PM
chris ST's Avatar
chris ST
sold mine at the start of the year ,
but before that had full decat piper exhaust (best sounding), radtec intercooler, dreamscience induction, custom map at NMS. never had it on the rolling road but was more than happy with how it went.
Old Apr 21, 2012 | 09:35 AM
Jay,'s Avatar
Jay,
Sponsor
me too also reliability issues ect such as clutches with power upgrades ect
Old Apr 21, 2012 | 09:51 AM
RichieST's Avatar
RichieST
Mine's got K&N induction kit (had the dreamscience one but was utterly shit), airtec FMIC, Full 3" turbo back milltek exhaust with sports cat, downpipe and resonated middle box, and a dreamscience race+ map.
The clutch does slip occasionally, it's down to the pressure plate not being strong enough, put in an RS pressure plate and it'll be fine. The rest of the clutch components are the same as the RS.
Apart from that, I've not had a single issue with the car in 3 years, and it gets abused!
Old Apr 21, 2012 | 09:54 AM
Carlos-Titx
RS clutches are good for around 400 bhp.
Old Apr 21, 2012 | 12:48 PM
Jay,'s Avatar
Jay,
Sponsor
any more info
Old Apr 21, 2012 | 12:53 PM
Carlos-Titx
What you after Jay?
Old Apr 21, 2012 | 01:31 PM
Jay,'s Avatar
Jay,
Sponsor
cheers for the chat Carlos just got to sell the evo now and find me a asbo
Old Apr 21, 2012 | 01:45 PM
Carlos-Titx
A pleasure mate. Had to pop out and pick mrs up from work.
I'll try and find that thread for you and have a look on STOC for a buyers guide as well so you know what to look for.
Old Apr 21, 2012 | 01:47 PM
Jay,'s Avatar
Jay,
Sponsor
yep time to sell the evo as think ive found a ford worthy to replace it
Old Apr 21, 2012 | 01:54 PM
Carlos-Titx
I love the sound the 5 pot makes when you boot it. Probably why I get crap MPG
Old Apr 21, 2012 | 03:38 PM
Carlos-Titx
Here you are Jay
Originally Posted by CarlosST3
Check thE seat bases ain't cracked. Operate the hight adjuster and wiggle the seat, they are prone to breaking and one corner will drop when sat in.
Alternators commonly fail and are an expensive fix.
Drive shafts are a weak point.
Models about that age have weak clutches so expect it to slip if you map it, but you could be lucky an have a strong clutch.
Oil diaphragms fail. Best repaired by using the Volvo part instead of ford.
Boost and oil gauges can play up usually due to a duff signal from maf/map sensors. Disconnect the batt for half hour would usually sort it if not new sensors.
Rear gearbox mounts are a bit shit, updated one is about Ł65.
It may have a space saver tyre, if not a compresor and tyre weld should be in the right hand corner of the boot.
Abs module can fail, Ł1400
Side skirts can come away from the body so check they are fitted correctly, covers for the headlight washers also come loose.
Remember the st3 only has 4 seats as well.
Will look now for a buyers guide.
*edit* thats a run down on what they have on the buyers guide on the owners site.
Old Apr 21, 2012 | 09:13 PM
LIMITLESS's Avatar
LIMITLESS
Cheers guys, all the info has been greatly received
Old Apr 21, 2012 | 09:18 PM
Jay,'s Avatar
Jay,
Sponsor
the evo has just gone up forsale to make way
Old Apr 21, 2012 | 09:24 PM
robbie1988's Avatar
robbie1988
Boosting around the NE
A brief spec of the power side of things;
RS injectors
RS spark plugs
Dreamscience decat
Dreamscience hybrid turbo (turbo X)
Piper catback
Magnex downpipe
Airtec plenum
Airtec intercooler
Pro Alloy cold pipe
Super size air filter
Roose inlet hose & intercooler pipework
RS oil cooler
Good for 352bhp and 435Ib/ft
Depends what your goal is power wise - stage 3 is great for all round use
Rob
Old Apr 21, 2012 | 09:27 PM
Carlos-Titx
Robs is definitely an amazing example of how an ST should be.
Old Apr 21, 2012 | 09:29 PM
GVK.'s Avatar
GVK.
Boost control solenoids can pack up giving little or no boost.
Other thing to look out for is cracked blocks giving misfire on hot start.
I have replaced an engine on an ST for this problem, not sure how common it is.
Would misfire then clear on hot start,removed plugs, one had signs of coolant contamination.. removed head cylinder 1 had a crack about 10mm deep in the top of the bore. New motor from Ford about Ł3k.
It's expensive kit, but the Mountune 260ps cars go very well IMO.
Old Apr 21, 2012 | 09:33 PM
robbie1988's Avatar
robbie1988
As mentioned above and something I forgot off my PM was the boost solenoid
I have only ever fitted 1 standard replacement just as a precaution- never had one go on me.
Now run an uprated iPD version and its alot better and gets rid of the Ford rubbish.
Cheers for the praise Carlos
Rob
Old Apr 21, 2012 | 09:34 PM
RichieST's Avatar
RichieST
Old Apr 21, 2012 | 09:37 PM
Jay,'s Avatar
Jay,
Sponsor
Originally Posted by RichieST
i hate you lot im selling my evo now i did love the sound the ones at the gate of central day
Old Apr 21, 2012 | 09:41 PM
Carlos-Titx
Shut it Richie lol.
GVK, was it the block or the liners that cracked?
Heard about liners cracking but never seen any one post teu had it happen. What causes it? Poor cooling?
Old Apr 21, 2012 | 09:42 PM
robbie1988's Avatar
robbie1988
Something like this noise Jay?
http://youtu.be/rhnqsHMZUH0
I will be honest the noise the ST makes was what got me into one to start with
Rob
Old Apr 21, 2012 | 09:46 PM
GVK.'s Avatar
GVK.
You would call it the liner, but on these engines they are integral to the block (not removable)
No idea what caused it but on this particular car had Bluefin and other mods.
(which were removed before bringing it in with fault)
Have had a couple with the spazzy gauges playing up, mostly cured with map sensor.
Gauges get info via CAN from ECU.
Old Apr 21, 2012 | 09:52 PM
Jay,'s Avatar
Jay,
Sponsor
Rob
stop it im 17 again
Old Apr 21, 2012 | 09:56 PM
Carlos-Titx
Am I correct in thinking that the gauges don't have a direct sensor but get the readings from others and from that can make the correct readings?
Old Apr 21, 2012 | 09:58 PM
GVK.'s Avatar
GVK.
Yep, that's how it works. 'calculated' Info gets sent from ECU/dash via CAN network.
Jay,'s Avatar
Jay,
Sponsor
by the sounds of it the ecu gets all the info then feeds the info to the dash i.e gauges ect through canbus
Old Apr 21, 2012 | 10:00 PM
robbie1988's Avatar
robbie1988
Yeah the boost gauge is quite away out alot of the time;
Here is the direct comparison between my stack gauge and standard boost gauge
http://youtu.be/NBR7pzQrlXg
Rob
Old Apr 21, 2012 | 10:02 PM
GVK.'s Avatar
GVK.
I can understand about boost gauge getting info from map sensor - ECU but as there's no oil temp sensor on the engine, it must calculate the oil temp via coolant temp etc? Guesswork basically.
Old Apr 21, 2012 | 10:03 PM
robbie1988's Avatar
robbie1988
Not sure on that but not fitting aftermarket temp gauges - going for AFR gauge next then thats it for me gauge wise
Rob
Old Apr 21, 2012 | 10:12 PM
Carlos-Titx
I had one day when oil temp was cold and pressure was max even once warm. That was on way to work, on way home it was fine and has been since. Duff signal? Did read pulling the kam fuse or disconnecting the battery for half hour can sort it some times. But map or maf sensor failure can also
Be at fault.
Old Apr 22, 2012 | 09:45 AM
LIMITLESS's Avatar
LIMITLESS
Rob
Originally Posted by Jay,
stop it im 17 again
Jay im in exactly the same position of you and Robbie isnt making it any easier with popping this awesome videos up
Old Apr 22, 2012 | 09:59 AM
Jay,'s Avatar
Jay,
Sponsor
what car do u have at the mo mate
Old Apr 22, 2012 | 10:02 AM
LIMITLESS's Avatar
LIMITLESS
Ive got a toyota corolla t-sport, but in the past ive had evos, r56 mini cooper s all played with and a red ka track car the richie bought off me and has now cossied, amazing what divorce can do to you lol
Old Apr 22, 2012 | 10:07 AM
Jay,'s Avatar
Jay,
Sponsor
lol i just fancy another ford but it needs to be a daily but fun ! done the cossie stuff and imo the hype is more than the car and i just think the st is a nice package not massive power BUT fun
Old Apr 22, 2012 | 10:12 AM
LIMITLESS's Avatar
LIMITLESS
Exactly the same as me mate, im thinking of getting it to around 300 and that will do
Old Apr 22, 2012 | 10:14 AM
Jay,'s Avatar
Jay,
Sponsor
we think alike lol i was thinking that not stressed ect plus im to old to chase numbers now lol
