my escort rs2000 cosworth NO LONGER FOR SALE
Old Apr 13, 2012 | 03:46 PM
cossytonyt's Avatar
cossytonyt
Default my escort rs2000 cosworth NO LONGER FOR SALE
selling my escort 90% finished just requires minor bits to complete,the car has been built to the highest standards using only the best parts i could find,
from the offset the car has been built to look as good as it will go.
please no daft comments if you,ve never built a car like this you really have no idea how much they cost !! to build to a high standard..
1979 rs2000 /4 previous owners /fully hpi clear.
quick spec anyone genuinely interested please give me a ring.
shell..superb shell converted from nosecone to flat front by myself using new wings/slam panel/front panel all of which are bolt on fully removable to make engineand box fitting easier in one lump.full underside of the car seam welded front to back/boot floor spare wheel well and tank well removed and replaced with one piece lightweight steel sheet / additional under body strengtheners added / jacking points /engine bay seam welded and gussetted top to bottom /triple top plates with additional bulkhead to strut tower strengtheners /custom twin strut braces tied to cage / modified bulkhead to accept vertually any engine choice....yb moved back 4 1/2 inches for better weight distribution / raised tunnel / handbrake location moved back /4 linked /turretted /panhard rod /with extra strentheners / tubbed /all arches rolled /multi point cage linked to front strutbraces,turretts,and 4 link boxes with removable door bars / firewalled /fuel filler removed /tank platform / seat rails / colour changed from white to olympic blue only mipa products used 8 ltrs inside/outside and underside done to high standard.
running gear... front gaz gold legs fully height and damping adjustable / group 4 alloy hubs /large bearings /forged steering arms/ instiu comp struts/insitu adjustable tca,s/green tre,s/2.2 quickrack/gp4 steering joint/wide track tarmac kit fully rose jointed/power steering in car adjustable/insitu adjustable top mounts/
rear...gaz gold height and damping adjust coilovers/ gp4 heavey duty 4 link kit/gp4 panhard rod/atlas axle with plated lsd.
brakes front.....hi spec billet 4 with 285mm discs
rear.....cosworth calipers with xr3i discs
engine......chassis mounted 205 block/wrc head gasket/lightly ported and polished head/bd16 inlet cam, standard exhaust/siemens injectors/hybrid t34/verniers/remote filter/big oil cooler/big intercooler/all custom silicon pipework/custom turbo and inlet dampers/new 2wd manifold heatwrapped/l8 ecu mapped 398bhp,very good t5 with quickshift/organic clutch {hydraulic}/3"simons ss exhaust.
loads of other stuff ie........sparco evo seats/fire system/willans harnesses/guages/snap off steering wheel/helmet net/new glass rubbers/alloy tank/spare wheelpost/battery box/pump holder/alloy washer tank/genuine ex btcc floor mounted pedalbox modified to suit escort.. etc etc etc
all the car needs to finish is...........front pipe making / prop shortening / new light kit for front / quarter bumpers /brakes plumbing in /new fuel pump and fuel lines/ loom fitting..
this car stands me near 18k but selling as i genuinely dont have the time or enthusiasm anymore going to take a break from the scene for a while.
looking for £13,500 ovno may consider selling as a fully trimmed shell minus engine/box/loom/ecu but would rather sell complete
this car will be worth strong money completed as it is not a cobbled together quick build 100s of hours and £kks have gone into the build tel tony 07899077111 cheers
Old Apr 13, 2012 | 03:52 PM
mothrs2k's Avatar
mothrs2k
MINT!!!
Old Apr 13, 2012 | 04:21 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
That's immense
GLWTS
Old Apr 13, 2012 | 06:57 PM
focusRSgirl's Avatar
focusRSgirl
RS65666
the best rs2000 ive ever seen
Old Apr 13, 2012 | 09:22 PM
nigel63's Avatar
nigel63
that looks fantastic,a real credit for the work done so far,shame your not going to finish it and take all the glory for a project that will excite all the people that will see it when its completed.
Old Apr 13, 2012 | 09:52 PM
777johnny's Avatar
777johnny
cheap as chips ,, wish i owned it
Old Apr 13, 2012 | 10:10 PM
gazcos's Avatar
gazcos
Tony, another car of yours I want to own !!! Gorgeous mate
Old Apr 13, 2012 | 11:17 PM
cossytonyt's Avatar
cossytonyt
cheers for the comments everyone really is better in the flesh than in the pics first to view will buy
Old Apr 21, 2012 | 03:01 PM
cossytonyt's Avatar
cossytonyt
no longer for sale
Old Apr 21, 2012 | 03:17 PM
Give it a few months and it will be up for sale again lol.It looks like a lovely car.Will be a bloody weapon on a track.
Vincereese
Jun 1, 2023 09:14 AM
LHD220Turbo
Aug 19, 2015 04:48 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Old ford
Jul 31, 2015 06:50 AM
