Do all rst's use knock sensors?
Old Apr 11, 2012 | 06:11 PM
Jamie_EscortSport's Avatar
Jamie_EscortSport
Default Do all rst's use knock sensors?
As above really???
Am i right in thinking its only the efi ones that use knock sensors as standard??
Old Apr 11, 2012 | 06:13 PM
GVK.'s Avatar
GVK.
No, the last of the Escort RST had one on the end of the inlet manifold with the green plug.
Old Apr 11, 2012 | 06:57 PM
martysmartie's Avatar
martysmartie
No ERST'S were EFI!
What he said ^^.
Martin
Old Apr 11, 2012 | 07:05 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Half the time your better taking the knock sensor off the manifold but keeping it plugged in and cable tied out the way as they pick up the rattley top ends on CVH's and retard the ignition for no reason...that's if the car isn't detting it's tits off to begin with
Old Apr 11, 2012 | 07:27 PM
Karlos G's Avatar
Karlos G
Balls Deep!
As above!! lol Rag it up out the way!
But yeah only late MFI RST's ran them, not the Fiesta EFI's.
Old Apr 11, 2012 | 07:42 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
series ones and d plate series 2's didnt, all later escort rst's did
Old Apr 11, 2012 | 07:56 PM
Jamie_EscortSport
ahh i have one then... first time iv seen one on the manifold,!
Old Apr 14, 2012 | 07:59 AM
gpm89's Avatar
gpm89
Ive been wondering about this, my D plate doesnt have one but the loom does? If the loom has it surely the ECU thinks it should be there too so would i gain anything from fittin one?
Old Apr 14, 2012 | 08:03 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
blue red blue and blue red white ecus don't have det sensor capabilities and can be used on all erst models
blue red black and hearts and diamond ecu's have to have a det sensor connected else they suffer from pmt
Old Apr 14, 2012 | 03:53 PM
homer j's Avatar
homer j
not strictly true. mine is a late E plate and that came with an early ecu and no knock sensor.
Old Apr 15, 2012 | 10:48 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Only if it's a knock sensor equiped ECU, if it's not then no problem.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
A.t.p
Oct 23, 2015 07:54 PM
fordrallycar
Sep 30, 2015 07:57 PM
