ZT Sounds like my dip stick is hitting something?! lol
Old Apr 10, 2012 | 09:03 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default ZT Sounds like my dip stick is hitting something?! lol
Have a listen to this video and take a look at the pic....
http://s413.photobucket.com/albums/p...t=IMG_1502.mp4
Now the tube is obviously no where near in it's original position because the manifold/PAS pump bracket fouls it, so I'm thinking the stick itself is pointing a different direction and maybe hitting the crank or a rod? Can't remember where it pokes out in relation to anything else though so not sure.
What have you other ZT owners that run the black top water pump done with your dip stick tubes?
Cheers!
Old Apr 10, 2012 | 09:11 PM
luke19790_3's Avatar
luke19790_3
think i kept mine in the original position, ire see if i have a picture
Old Apr 10, 2012 | 09:14 PM
foci's Avatar
foci
I know when the zetecs were new. A few M.O.T centres broke zetecs as they had to take the oil temps for the emmisions from the dipstick. the sensor would go to far down and wrap round the crank
Old Apr 10, 2012 | 09:29 PM
Karlos G's Avatar
Karlos G
Balls Deep!
That would be handy to see mate cheers!
I think it's only diesel engines that you meassure oil temp?!
Old Apr 10, 2012 | 09:39 PM
luke19790_3
can't find a picture with the engine in the car and themanifold fitted, but mine fits like this. But i'm not using a rst manifold.
Old Apr 10, 2012 | 10:03 PM
Karlos G's Avatar
Karlos G
Balls Deep!
You know I think my tube might be a different shape to that..... Google images here I come...
Old Apr 10, 2012 | 10:06 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yes thats my problem! Look where a ST170 dip stick is supposed to be....
Which is what I have as it's a ST170 bottom end!
Looks like I just need a normal black top dip stick tube!
Old Apr 11, 2012 | 05:23 PM
SiZT's Avatar
SiZT
Won't fit (w/o modification) with an RST manifold, what does the tube look like where it enters the block? Is it on the piss?
Old Apr 11, 2012 | 05:38 PM
Karlos G's Avatar
Karlos G
Balls Deep!
What won't fit, a normal Mondeo one?
Old Apr 11, 2012 | 06:16 PM
luke19790_3
Old Apr 11, 2012 | 06:36 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
just get a regular blacktop dipstick and tube.
my blacktop stick and tube clears manifold just fine, essentially the st170 block/sump is the same.
Old Apr 11, 2012 | 09:31 PM
crazycage's Avatar
crazycage
thats a nice inlet!!
Old Apr 12, 2012 | 04:32 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Just FYI I carefully bent the tube into the shape of a normal Mondeo one and it no longer hits anything!
Old Apr 13, 2012 | 06:55 AM
Rogeyboy's Avatar
Rogeyboy
Nicely done... Looking forward to seeing this car in the metal
boeb
Jan 9, 2020 05:11 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
