Stage 3 Evolution chip L6, 2WD & 4WD Interccoler,803's
MSD Evolution chip for sale spec below- 60 pounds inc. postage
Calibration Specification
4WD Intercooler - 20 pounds PLUS postage
Set of Bosch green injectors- 75 pounds inc. postage
All parts in good condition, can provide photos if required.
- ECU Type: L6 ECU
- Babyboard Required: No
- Pectel or Weber: NA.
- Encryption Key required: Yes - Green-A
- Engine Type: Ford YB 2.0
- Engine Compression: Standard
- Head Spec: Standard
- Camshaft Spec: Standard:
- Injectors: Siemens 55lbph LI
- Turbocharger: T34.63
- Map Sensor: 3 bar
- Intercooler: RS500 type
Additional Features Installed: - Closed Loop active: No
- Air Injectors active: No.
- Serial Data active: No.
- Anti Lag active: No
- Launch Control active: No
- Flat Shift active: No
Also found an AB stage 3 chip, designed for L8 ecu with PECTEL board (Chip only), 45 quid posted.
(Standard engine with T3/greens/3 bar)
Russ Payne
Sep 25, 2015 08:29 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
