2wd steering rack joint/knuckle
Old Apr 9, 2012 | 08:14 PM
GINGExR2 T's Avatar
GINGExR2 T
Default 2wd steering rack joint/knuckle
Been digging out some bits for the S2 cossie project today as i need to look at sorting the steering rack out soon, now the lower knuckle joint that joins the rack to the colum has a rubber bush / doughnut in it, this was a replacement 18 months before the saff was striped and has been boxed in storeage for the past 6 years. Noticed today that the bush has started to split and is held in with rivets rather than nut and bolt.
Anyone know if the bush is replaceable, or is there a non bushed one i can use. i've noticed the 4x4's don't have the bush insert, do these fit as a replacement.
Cheers,
Ginger
Old Apr 13, 2012 | 11:05 PM
mark r's Avatar
mark r
yeh burtonpower sells that rubber for about 35 notes
Old Apr 15, 2012 | 12:15 PM
GINGExR2 T's Avatar
GINGExR2 T
Cheers mate, had a look on there and can't seem to find them, i'll have to give them a ring.
Ginger
Old Apr 15, 2012 | 12:23 PM
Miller 3's Avatar
Miller 3
Im swapping over to 4x4 stuff.
Old Apr 15, 2012 | 03:59 PM
Mr C's Avatar
Mr C
The 4x4 is a different length to 2wd so won't fit, that also has a rubberised insert but is between the shaft and tube not an unsupported disc
tankybaby66
Feb 6, 2016 02:24 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
IainRS1700T
Sep 25, 2015 06:44 AM
