Who to build my new esc cos engine???
im going with the idea that im one piston down!
if this is the case... i need my bottom end rebuilt
whats the process? strip it or send it off to someone to rebuild?
i guess id be better off taking the head and block somewhere to have them both overhauled??? then fit the bastard back in myself
who are the guys to do this for me?
SCS?
Martin Hadland?
Karl Norris?
id like it done asap really
cheers all
SCS?
Martin Hadland?
Karl Norris?
cheers all
surely you are going to check it over before condeming the engine to a full rebuild, when it might just be a fuel regulator gone down or a headgasket failure
as after all you said it did recover when it first dropped onto 2 (piston failure doesn't usually recover
Pugo
)Pugo
i just want a bullet proof stg 3 to 400 brake engine
Bulletproof doesnt exist in my view...
In my view.. its not the case IF it brakes down .. but rather WHEN it brakes down .. rather later then sooner..
but something we have to live with driving YB on high power
scs for me, harvy is away at the moment in usa, a good 400+ bhp engine will need the head porting as well and the price for scs to do the work is about Ł7000 but that is for the hole job, you just drop the car off and pick it up all sorted latter
Cost of a 400bhp engine depends on what your starting with. Just had mine done.
cost me Ł3300, but it was running that power before it melted a piston,
Not complaneing the engine had done 32,000 hard driven miles
Dave
PS A1 rally sport did the job
Dave
Originally Posted by ImaRacing 700
Anyone can build an engine...especially a conversion like you want Dave...its the mapping you gotta get right
so build and spec it yourself and get phil to map it
what prices am i looking at guys for the bottom end to be rebuilt
please let me know if ive missed anything out
Block cylinders bored
new pistons & rings
Bearings + shells
balanced
all the above assembled
do i stick with std headbolts and use a WRC 4 layer gasket?
im afraid im now in virgin territory
and would appreciate advice
still havent checked the plugs... hollyoaks is still on
new pistons & rings
Bearings + shells
balanced
Slighty of topic Dave, i'd like to volenteer my services to you.
I can make a blinding cuppa and prob be your bitch for the day.
Let me know..........I'd quite enjoy a day's leaning about Rs Turbo's from you too
there was a brand new 4x4 short block on ebay the other day which i think didnt sell! might be worth trying to track down the seller? ( is it possible?)
other than that i would phone around nms, msd, scs, mad, JG and see who can fit you in
Originally Posted by Toe Knee
As Lee said they are all good at what they do, to be honest your better off ringing them up rather than askin us mate
A1 rallysport built my engine, really good with the price too.
As for which gasket etc.......
i am in the process of fitting a new gasket on mine at the moment and i'm fitting a cometic metal one with arp studs i think.
these should be good for your 400bhp spec if you do go down that road.
Dave.
Dave.
Originally Posted by Ryan
the brand new block was direct from cosworth in Northampton, was also a new head on there aswell.
we had this problem before xmas lookin for a block for kevs
When I went to see Harvey a couple of years ago it was shit loads cheaper then that!!!
Does that include MikeR's advertising fees then? lol
There's a couple of tuners that you can go to. Like Porkie said, call them and others that haven't been mentioned and find out who can fit you in.
Now that I'm thinking about it...I'm wondering if I should get Tiff to send me some of his crackers and make the tea...could this lead to a tuner's war? LOL...
PassionFords Creator
All builders will have a written engine build spec and costings document of some form thats fully itemised i expect Dave as its a pretty standard procedure if staying under 400 bhp, just call/mail them all and get it E-Mailed across to you, then simply choose the one you fancy and above all trust..
