What gearbox H.O. rwd Cosworth?
Old Apr 5, 2012 | 02:54 PM
Jasu's Avatar
Jasu
Default What gearbox H.O. rwd Cosworth?
Or can I just change stronger gearkit to T5?
Old Apr 5, 2012 | 02:55 PM
JamesH's Avatar
JamesH
What does H.O mean?
The best gearbox you could get, which is basically bullet proof, is a Tremec TKO600
Old Apr 5, 2012 | 03:00 PM
Jasu's Avatar
Jasu
Originally Posted by JamesH
What does H.O mean?
High Output.
Does TKO600 change well in high rpm?
Who sells those and what price?
Old Apr 5, 2012 | 05:00 PM
JamesH's Avatar
JamesH
Rod Tarry has one and I think he revs to 8200rpm or higher. You're probably best ordering one from America
Old Apr 5, 2012 | 06:19 PM
LHD220Turbo's Avatar
LHD220Turbo
how much torque?
Old Apr 5, 2012 | 06:34 PM
Jasu's Avatar
Jasu
Originally Posted by LHD220Turbo
how much torque?
Don't know, engine is not ready yet. Somewhere between 700-800Nm I think. I'm hoping to finish it for the summer.
Old Apr 5, 2012 | 06:37 PM
MAD Ade's Avatar
MAD Ade
Rod's has been revving to 8900 up until recently without any problems with gear change
Old Apr 6, 2012 | 09:40 PM
Jasu's Avatar
Jasu
Sounds good.
What about v160 gearbox? Has anyone tried it?
Old May 20, 2012 | 04:17 PM
Jasu's Avatar
Jasu
Do you know what TKO600 Rod has?
Old Jul 20, 2012 | 05:32 PM
Jasu's Avatar
Jasu
Found today Liberty's TKO600 with 0.64 fifth gear. Just need to find suitable diff with better ratio.
Old Jul 24, 2012 | 06:52 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Mine has a .83 5th gear the .64 is not suitable with a very large gap between 4th & 5th almost like falling off a cliff. Its an overdrive gear in typical American style.
Old Jul 24, 2012 | 06:25 PM
Jasu's Avatar
Jasu
True Rod, must be best to change the 5th gear.
I'm going to also use Sachs -765 PP with this one. That holds over 900Nm with sinter and is much nicer to use than multi-plate clutches.
Oct 9, 2015 07:38 PM
CLIVE
Oct 2, 2015 12:58 PM
Marc sierra
12
Aug 30, 2015 10:38 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
