Cossie power steering problem
Old Apr 4, 2012 | 07:21 PM
KSA-Cossie's Avatar
KSA-Cossie
Default Cossie power steering problem
Have replaced the pump and rack but its still stiff when stationary and comes and goes as you're driving Going to replace the belt abd tensioner,anything else I can try ?
Old Apr 4, 2012 | 07:45 PM
dakar's Avatar
dakar
Jesus Kev,cant believe your still having hassle fella
Old Apr 4, 2012 | 07:53 PM
baggy1979's Avatar
baggy1979
RS geek
Has any of the banjo bolts got filters in them that could be blocked.Failing that forte use to do a power steering treatment which has to be used to be believed,well worth a try if still available.
Old Apr 4, 2012 | 08:22 PM
KSA-Cossie's Avatar
KSA-Cossie
Yeah Steve,pure nightmare matey.
KSA-Cossie's Avatar
KSA-Cossie
Dunno mate,gonna try new hoses too.
Old Apr 4, 2012 | 08:27 PM
155lee's Avatar
155lee
You checked the knuckle under the turbo?these dry up with the heat and go really stiff,I drove 1 with a knackered knuckle and it felt very strange,it was sometimes light then went tight,matter of fact I've drove 2 with the same fault and a new joint cured it both times.
Old Apr 4, 2012 | 08:29 PM
KSA-Cossie's Avatar
KSA-Cossie
No,but good shout mate.
Old Apr 4, 2012 | 08:36 PM
RONNIE AMIS's Avatar
RONNIE AMIS
was just about to say to try the uj from column to rack, they give a horrible feeling as if the car wants to carry on steering itself and doesnt return properly
Old Apr 4, 2012 | 08:53 PM
KSA-Cossie's Avatar
KSA-Cossie
Thanks Ron,can you still get new ones ?
Old Apr 4, 2012 | 08:55 PM
RONNIE AMIS
is yours 2wd or 4x4 kev?
Old Apr 4, 2012 | 09:00 PM
KSA-Cossie's Avatar
KSA-Cossie
4x4 mate. I heard from James your motor is a weapon,also that the airtec cooler is mega,so I've bought one too lol.
Old Apr 4, 2012 | 09:06 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Is yours mapped now Kev ?
Tony advised me to heat wrap my steering knuckle
Steve
Old Apr 4, 2012 | 09:09 PM
KSA-Cossie's Avatar
KSA-Cossie
Steve
Not live mapped no,the above fault has made it unsafe to map flat out.
Old Apr 4, 2012 | 09:12 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
So you have got to sort your rack and fit your new intercooler then go back ?
Steve
Old Apr 4, 2012 | 09:16 PM
Miller 3's Avatar
Miller 3
Why is it unsafe? Who wants to know where your going! Bloody pusseys lol x
Old Apr 4, 2012 | 09:18 PM
KSA-Cossie's Avatar
KSA-Cossie
Steve
Unfortunately so Steve. but I've been given a new safer map meantime.
Old Apr 4, 2012 | 09:19 PM
KSA-Cossie's Avatar
KSA-Cossie
Lol,that would be James then.
Old Apr 4, 2012 | 09:21 PM
chrisa3's Avatar
chrisa3
The steering on my 2wd has been stiff since building it up last year. What is the difference between the 2wd setup and 4wd setup?? I ask because mines a 2wd, but someone has fitted a 4x4 adjustable steering column in the past and im wondering if its stiff due to a compatibility with the steering joint. Mine has a rubber donut in the middle of the UV joint.
Old Apr 4, 2012 | 09:22 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Should be better with the new intercooler anyway
Steve
Old Apr 4, 2012 | 09:34 PM
rapidcossie's Avatar
rapidcossie
When Sheady mapped mine originally the sterring knuckle was fucked, and it was snowing! lol
Nutter!
Old Apr 4, 2012 | 09:42 PM
RONNIE AMIS
i would try the uj, i will see if dan yap has hes one for sale, i could bring it up saturday if so?
wicked mate, yes james told me nothing above 19.7 act's
it goes a bit better apparently
Old Apr 4, 2012 | 10:06 PM
KSA-Cossie's Avatar
KSA-Cossie
That would be brilliant Ron, cheers mate.
Old Apr 5, 2012 | 05:59 PM
155lee's Avatar
155lee
It's easy to check,undo the 10mm bolt on the knuckle where it clamps onto the column and it will come free so you can move it by hand,if you can't move it it's fooked.
Old Apr 5, 2012 | 07:28 PM
KSA-Cossie's Avatar
KSA-Cossie
Will try it mate,thanks.
Old Apr 5, 2012 | 08:56 PM
xr4x4rs's Avatar
xr4x4rs
scrap it lol
sounds like an air lock, or rack knackered, did you fit a reconned rack or a second hand one?
and what was the reason you changed the rack
Old Apr 6, 2012 | 01:09 AM
Miller 3's Avatar
Miller 3
Thinking about this, i had this on a 7.5 tonne lorry, it would jusy not bleed up! I had to jack up tje front to take the load off. worth a shot!
Old Apr 6, 2012 | 06:15 AM
KSA-Cossie's Avatar
KSA-Cossie
Originally Posted by xr4x4rs
scrap it lol
Thanks Rich fitted a new pump and a known working 2nd hand rack. I replaced the p/s reservoir with a crackle one and after re-fitting the power steering was stiff.
KSA-Cossie's Avatar
KSA-Cossie
Gonna give it a good check over when I get it back doug.
Old Apr 6, 2012 | 11:19 AM
I would of said it could also be the uj. We have a few ldv maxus vans at work and these do this.
Old Apr 6, 2012 | 07:04 PM
xr4x4rs's Avatar
xr4x4rs
does it go stiff or judder?
Old Apr 6, 2012 | 07:24 PM
KSA-Cossie's Avatar
KSA-Cossie
Goes stiff Richie
Old Apr 6, 2012 | 07:26 PM
RONNIE AMIS
It's strange how it's happened since you've done the rack which doesn't point toward the uj. But the problem sounds like a uj
Did you not have a look at it today matey?
Old Apr 6, 2012 | 07:59 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Same prob i had after fitting my almost new said to be as new pump i got off a mate! it wasent giving full pressure and felt like i had no power steering at stand still and on the move it was very stiff! when i took it apart the vains were all stuck so not pressurising the oil
Old Apr 6, 2012 | 08:20 PM
xr4x4rs's Avatar
xr4x4rs
i have a full working pump here that came off my escos if you need to try another pump
Old Apr 6, 2012 | 09:15 PM
KSA-Cossie's Avatar
KSA-Cossie
It actually started after I replaced the reservoir with a crackled one Ronnie.
Old Apr 6, 2012 | 09:16 PM
KSA-Cossie's Avatar
KSA-Cossie
It's still at MSD Glenn.
KSA-Cossie's Avatar
KSA-Cossie
It was a brand new pump James,but I'm not ruling that out yet.
Old Apr 6, 2012 | 09:17 PM
KSA-Cossie's Avatar
KSA-Cossie
Thanks Richie,but the pump is under warranty so can get another.
Old Apr 6, 2012 | 09:18 PM
Ok then. Can you not get them to have a quick look at it.
