Yb Swedish plenum
Swedish plenum and throttle cable bracket.
Has been used, changing engine specs so no longer needed.
Holes for sensor and vac pipes at far end.
Good conition.
£150, plus p&p
Good conition.
£150, plus p&p
bolts to motor no bother as inner part is std. You have to move ACT and ICV wiring a bit. The intercooler to throttle body pipe has to be moved upwards. Cheers
Looks like its made for standard 4x4cossie fuel rail.
But one of mk Motorsport 'sto universal billet fuel rail's would look nice on there.
I've got one of these for my car but had clearance issues with the pipes/sensor bieng at the rear so had the holes welded up and re tapped them on the underside out the way
Cheap Swedish though
timsrs
22
Sep 24, 2015 08:14 PM
