need help please
Old Apr 4, 2012 | 08:11 AM
s2erst's Avatar
s2erst
Default need help please
right on my zetec i want to know where the coolant sensor is as i have 2 that look the same one which is in the inlet manifold an one that is in the themostate housing reason i ask is i have very bad cold starting an this always seems to be the problem so want to change it cheers
Old Apr 4, 2012 | 11:10 AM
Rob_DOHC's Avatar
Rob_DOHC
Hi mate,
Sorry i forgot to txt back! If you plug your laptop in what temperature reading do you get? I would check this before replacing the sensor, your clt sensor may just need recalibrating.
Rob,
Old Apr 4, 2012 | 11:51 AM
s2erst's Avatar
s2erst
Originally Posted by Rob_DOHC
Hi mate,
Rob,
i was hoping you would reply rob lol. ive just ordered new one from ford anyway. it done it with my std ecu today anyway. what ill do is fit the new one an see if it sorts it out an if it dont ill give you a call if thats ok mate cheers
Old Apr 4, 2012 | 11:56 AM
Rob_DOHC's Avatar
Rob_DOHC
Yea no worries mate, what sensor did you order? IE) what model car was it from?
Rob,
Old Apr 4, 2012 | 12:03 PM
s2erst's Avatar
s2erst
Rob,
i used parts number from my one looked it up an its a fiesta one anyway so its right i hope lol
