Can you drill alloys and insert screws?
Old Apr 3, 2012 | 11:40 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Default Can you drill alloys and insert screws?
Hello,
As title really, i want to drill a hole say 3mm and insert a 4mm screw or something similar. This will be near the middle of the alloy, well in between where you bolt it on.
Cheers.
Old Apr 4, 2012 | 12:49 AM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
I Wouldn't,
Old Apr 4, 2012 | 06:18 AM
focusv8's Avatar
focusv8
To fix some sort of centre cap?
Some alloys have holes for that so it would be O.k
Old Apr 4, 2012 | 11:16 AM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Yeah i wanna screw a centre cap in but there is no hole for it, i didnt know if i could drill a hole and screw it in to stop thefts?
Old Apr 4, 2012 | 12:05 PM
stu21t's Avatar
stu21t
Ive got a set of alloys that have centre caps screwed on.
Theres 3 m6 bolts holdin them on in a triangle.
I would say its fine if theres enough meat there.
If you only do 1 then you need to balance the wheels after tho.
Old Apr 4, 2012 | 12:53 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Well after hearing everybody say there centre caps go missing on the fiesta ST made me think what can be done? Other's silicone them in or glue and put there car number plates and names on the back but people can still take them, Just a screw drilled though would stop them i think, well for a while anyway.
Just a simple screwdriver could remove it but theft's normally dont carry a set of screwdrivers (well a flat headed one) I could put say a allen key sort in.
It would be in between the nuts here.
Old Apr 4, 2012 | 01:00 PM
surrey_100e's Avatar
surrey_100e
something like this?
Old Apr 4, 2012 | 01:02 PM
gouch1's Avatar
gouch1
i have done that before never had any problems i used a small allen bolt
Old Apr 4, 2012 | 01:09 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Surry_100e:
Well it wont look as good as that but just a black screw, i dont think you will see it very well.
Gouch1:
You have drilled a alloy and put a screw in? I just wanted to put a screw in slightly bigger than the hole so it self taps itself.
Old Apr 4, 2012 | 01:19 PM
vroomtshh's Avatar
vroomtshh
I'd be tempted to drill and tap the head of the locking nut, save damaging the wheel
Old Apr 4, 2012 | 02:24 PM
surrey_100e
i was thinking something along the lines of that one too, good idea.
Old Apr 4, 2012 | 03:50 PM
zippyobrien's Avatar
zippyobrien
It's 100% fine. If you look in the wheels for sale page I did just this to a set of fiesta St wheels.
Never lost another cap. Drilled and tapped a m5 whole and used m5 counter sunk bolts.
Old Apr 4, 2012 | 03:54 PM
focusv8's Avatar
focusv8
There not missing, they just aren't with the original owner;
http://www.ebay.co.uk/itm/ford-focus...#ht_500wt_1023
Old Apr 4, 2012 | 06:14 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
yes ive done it, ive used both threaded holes with a tap and a clinchnut (thread insert) banged into a hole 1/2 mm that the nut (thread insert is far superior)
never had to balance just like ive never balanced a wheel because ive lost a centre cap (the centre and the bolt will be elsewhere when its on the machine anyways so the gram or 2 of alu wont make any odds) then a good sized bolt with a wide top otherwise a tug will have teh cap gone ether its got a bolt in ot not, i like these but stainless
http://s7g3.scene7.com/is/image/ae235?$p$&layer=0&size=281,281&layer=1&size=281,28 1&src=ae235/64094_P
biut security bolts and cooler and with a good sized head wont be pulled over (st centre caps are plastic aint they?)
Old Apr 4, 2012 | 06:15 PM
1.9 xr2 on 40's
st170 breaking
these ?
http://www.ebay.co.uk/itm/M6-x-20-ST...item2302928274
Old Apr 4, 2012 | 06:42 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Thats great! I knew i could not be the only one who has thought of this! Have you got a picture of the alloy without the cap on?
Better stock up now lol.
Old Apr 4, 2012 | 06:48 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
I think i got a little lost here, Ive never seen a "clichnut"?
Have you got any pictures of said work done? Yeah the st centres are plastic.
Old Apr 4, 2012 | 06:54 PM
1.9 xr2 on 40's
st170 breaking
its a thread insert, you make the hole (like in a wall) put in the threaded bit and the bolt will go into it, its a very good fitting
http://2.imimg.com/data2/MG/QO/MY-51...cv-250x250.jpg
like that but i like the others with rifleing to the outside endge to fit it really tight
Old Apr 4, 2012 | 07:00 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Might be a good thing to do! I think ive got to have a look and suss out the situation.
Old Apr 4, 2012 | 09:45 PM
zippyobrien
My wheels sold but if you look in the wheels for sale section / St fiesta wheels. There's pictures on there mate.
Old Apr 18, 2012 | 03:42 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
I still have not done anything about this! The plan is to drill and put my own thread into the alloy then just insert a screw. Seems simple. Ill upload pictures when ive done it.
Old Apr 18, 2012 | 03:48 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
I must do this i'm fucking sick of buying center caps for my ST.
Old Apr 18, 2012 | 04:41 PM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Im not the only mad person! Ive never had mine taken but i know it will happen! Also i want to put cable ties on my jack covers!
Old Apr 18, 2012 | 09:39 PM
STAFFY OWNER's Avatar
STAFFY OWNER
This is probably the best suggestion as aluminium is well known for threads stripping especially on threads that are likely to be used frequently as it is so soft, at least the wheel nut would be steel and take a good thread. Clinch fasteners are usually used with sheet metal applications so not really suitable in this instance. If you must have the thread in the alloy these inserts would be the best solution as the thread that will take the screw will be stronger than an aluminium thread and unlikely to strip.
http://www.harrisonsilverdale.com/fa...7/HPI/108.html
Old Apr 18, 2012 | 10:12 PM
mk22door's Avatar
mk22door
Fart of the Purniture
I was only talking to my old man about this with regards to my TSW Imolas.
Only thing is with them the bloody great nut that holds the centre cap on, I'm liking the thoughts and answers here
Nice one chaps
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
