Fan switch plug required.
Old Apr 2, 2012 | 08:18 PM
wakesupremo's Avatar
wakesupremo
Default Fan switch plug required.
I need the plug off the switch from a rad top hose out of an escort. I stripped a 1994 escort zetec SI for my sons 100E and fitted all the ecu etc. The bit I must have left in the escort was the plug from the fan switch. I have visited 3 breakers yards today thinking it would be a simple job just to pull the plug off and cut the wires. Out of all the zetec powerd cars there none had this switch in the top hose. Was mine the only one that was fitted with this switch?
Old Apr 2, 2012 | 08:40 PM
marvin's Avatar
marvin
My zetec Mk 3 and (Mk 3.5) Fiesta (XR2i 1993) have the switch in the Rad....22 x1.5mm thread 80 deg c (if thats of any use?) From memory though think the loom has a two pin socket.....
Old Apr 3, 2012 | 04:21 AM
The 2ltr zetec engines in the mk1 focuses have them. The sensor and plug us cabled tied up next to where the battery sits.
Old Apr 3, 2012 | 06:09 AM
wakesupremo
Thanks I'll have to have a look at one of those then.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
rsguy
44
Sep 29, 2015 03:29 PM
deathrider666
Sep 28, 2015 06:12 PM
cossie330
Sep 27, 2015 04:13 PM
