Anyone know there oils....
Cant seem to get a straight answer so will try on here as its a more friendly site!
Need to know which oil for a 3.2 2001 XJ8 rear diff, its NOT got LSD (traction control instead).
Theres no drain so plan to remove some oil and fill up as much as possible
Cheers all!
Neil
Cheers all!
Neil
Transmission, automatic ZF 5/1 - FLUIDE XLD FE
Hydraulic brakes system with ABS - HBF 4
Hydraulic clutch system - HBF 4
Power steering - FLUIDE ATX
Engine AJ-V8 - QUARTZ 9000 5W-40 OR QUARTZ 7000 10W-40
think thats all the oils for your car
if you need i can sort the oils out for you and get them posted down to you
give me a call tomorrow on 01286 669 699
these oils are all Total oils.
Rich.
Rich.
