I've been a busy boy today.....new engine with pics....
Thought i'd post this in the general discussion cause not everyone looks in the rebuild section
Well another day spent on the rebuilding of my engine and there has been great progress
Spent a bit of time painting some bits and bobs and cleaning certain things
heres the results.......
First on was the exhaust manifold with new studs
Then the inlet
sender for oil temp gauge....
Then on went the oil cooler pipe work, filter and dizzy cap and leads
Then finally the turbo and damper
Get some more bits in the week and an engine hoist to refit it and get it up and running
Spent a bit of time painting some bits and bobs and cleaning certain things First on was the exhaust manifold with new studs
Then the inlet
Thanks for ya kind words
IMA....I had to sacrifice some stuff so i could have a decent internal build,i will paint the cover later when the engine is in
lol....was thinking that the bolts for the turbo where a little large but they don't look to bad,the pics make them look bad to be fair
Originally Posted by 3DOOR ARY
looking good buddy
still gonna put you at the back at the shows though
Thats right baldy you will
BUT.....
You'll be at the back on the road
lol....sorry dave
MBE race engines in lincoln built it dude and its had....
NEW Pistons,Rods bearings Ł460
ARP stud and nut kit for mains and head Ł240
ARP Rod bolts Ł90
ARP flywheel bolts Ł30
NEW AP Racing clutch kit with Group N cover Ł320
4X4 High pressure oil pump Ł180
Cometic head gasket Ł120
Piper verniers Ł170
Water Pump Ł60
Take apart and rebuild with Rebore (+1mm oversize)
Fully Lightened and balanced , high comp
reconditioned head Ł800 labour that all comes to Ł2400
There are loads of other stuff too cause it has cost me around Ł3.7k with all the goodies i've purchased
ARP Rod bolts Ł90
Piper verniers Ł170
Water Pump Ł60
There on the same block as Paul Goy Racing on the Allenby Industrial estate off monks road. The chap who runs it is Mike Barrett and does alot of engines for rally cars so knows his stuff
He doesn't have a dyno but uses paul goy's RR for testing bits and bobs and has a motec set up for testing when going down the road.He has all the engineering machines in house so he just gets on with it
cheers keith, so that Ł2800 includes all the parts and fitting labour youve listed?
what pistons did you use? mahle?
cheersmate
Dave
cheersmate
Dave
Yes mate.... and i used Mahle with std comp
Another update........
Just spent the last 3hrs installing the engine and its coming on pretty well now
took me time just to make sure i hadn't forgot anything
must be about -2 here aswell
going to carry on with it tomorrow night so i put some more pics up
Heres some from tonight
coming together just lovely
took me time just to make sure i hadn't forgot anything Heres some from tonight
Ben26
Aug 27, 2015 08:56 PM
Like Imaracing, I would see to the Cam Cover as well.
