sierra camber shims
Old Apr 1, 2012 | 05:43 AM
AndyR1's Avatar
AndyR1
Default sierra camber shims
hello can any body tell me where i can buy some sierra camber shims for the rear hubs,cheers andy
Old Apr 1, 2012 | 06:16 AM
Juan Nogueira's Avatar
Juan Nogueira
mike rainbird R&B Motorsport
Old Apr 1, 2012 | 07:36 AM
cos 4x4's Avatar
cos 4x4
There a guy on the sierra owners forum makes them on there
Old Apr 1, 2012 | 08:42 AM
DAN-Saff's Avatar
DAN-Saff
Or you can make some out of 1mm steel sheet
take hub off cut to fit bolt holes without fouling driveshaft bolt back together.
Old Apr 1, 2012 | 08:50 AM
cossiestu's Avatar
cossiestu
Don't they fit under the top/back 2 studs or something?
Old Apr 1, 2012 | 08:58 AM
Rsmat's Avatar
Rsmat
Here's mine fitted.
Old Apr 1, 2012 | 09:03 AM
AndyR1's Avatar
AndyR1
thanks for the info lads
Old Apr 1, 2012 | 10:49 AM
marco polo's Avatar
marco polo
Originally Posted by Mom say's im specail
Here's mine fitted.
Just Curious ...... but how much negative camber does those shimms give you say on standard ride hight ?????
marco
Old Apr 1, 2012 | 10:54 AM
Rsmat's Avatar
Rsmat
marco
Not sure on standard ride height... As mines dropped 20mm on Ahmed springs... Iirc they make up the 6degrees mate.
Old Apr 1, 2012 | 11:07 AM
Ade500's Avatar
Ade500
Fixing Fords
They are only for small corrections I think mate.
Old Apr 1, 2012 | 11:22 AM
snoopaloopa's Avatar
snoopaloopa
Bettison on Fsoc site sells them and sometimes on ebay too.
1mm steel will make a 1mm spacer, not a cambered shim
martysmartie's Avatar
martysmartie
marco
They don't, thats the problem, they remove the negative camber and so give the tyres a better foot print (This is why they wear on the inside edges)
I should imagine even on standard ride height they may help as due to how low they sit thats what causes the negative camber, especially on 2WD models.
Martin
Old Apr 1, 2012 | 12:28 PM
PAUL S's Avatar
PAUL S
make sure you get the bearing carriers reprofiled so that the bolts can still sit flush when they are torqued up or the heads could snap off, I believe Matts already had this done to his.
Old Apr 1, 2012 | 12:35 PM
DAN-Saff's Avatar
DAN-Saff
Not if you only put it under 2 bolts which is what you do if you fit the r&b kit.
Old Apr 1, 2012 | 01:12 PM
Rsmat's Avatar
Rsmat
Yea that's right Paul... It's piece of mind more then owt.
Old Apr 3, 2012 | 05:14 PM
marco polo's Avatar
marco polo
Martin
Alright Martin
I understand how they work........... .lol.... i was just wounding how much negative camber they would take out on standard car hight
marco
Old Apr 3, 2012 | 05:31 PM
Tony Ryan's Avatar
Tony Ryan
2 degrees max Marco , i always used Dennis from Domes ones ,anything more and they hit the Abs ring on the driveshaft mate .
Old Apr 4, 2012 | 06:16 PM
rik-rs's Avatar
rik-rs
just found a set on ebay for 35 quid, is that expensive???
Old Apr 4, 2012 | 06:42 PM
Ade500's Avatar
Ade500
Fixing Fords
Yep they are Ł27 on the FSOC mate, I think that's posted too.
http://forum.fordsierraclub.co.uk/se...s=camber+shims
Old Apr 4, 2012 | 06:58 PM
graham c's Avatar
graham c
link please
Old Apr 4, 2012 | 08:51 PM
Ade500's Avatar
Ade500
Fixing Fords
above
Old Apr 5, 2012 | 06:27 AM
graham c's Avatar
graham c
thats ok if your a member tho some one pm me please
Old Apr 5, 2012 | 06:47 AM
rik-rs's Avatar
rik-rs
that site didnt work for me either
Old Apr 5, 2012 | 06:52 AM
graham c's Avatar
graham c
trouble joining the site for me
Old Apr 5, 2012 | 08:20 AM
R4N SS's Avatar
R4N SS
ive got mine fitted but havent driven it yet so cannot comment - car is lowered a fair bit too. They are the same as Ade and Matt's from that Bettison guy on FSOC.
Look a better kit than the R&B items too imo
Old Apr 5, 2012 | 08:54 AM
GINGExR2 T's Avatar
GINGExR2 T
Could you not just use a shimmed washer and longer bolts????
Ginger
Old Apr 5, 2012 | 10:07 AM
Rsmat's Avatar
Rsmat
Ginger
You could but how safe they are would be a concern... The shims spread the loads over the correct surface area.
Old Apr 5, 2012 | 10:37 AM
Gary F's Avatar
Gary F
This might be a stupid question but can you use shims on the front too?
Old Apr 5, 2012 | 02:42 PM
GINGExR2 T's Avatar
GINGExR2 T
Sorry, not instead of the camber shim mate, i ment instead of having the bearing carrier modified so the back of the fixing bolt sat flat on the face, just use a washer of the same angle as the main shim, I hope that makes sence
Ginger
Old Apr 5, 2012 | 06:19 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
How thick are they Matt, If i recall when i fitted mione which i got from Mike they were only very thin shims?
Steve
Old Apr 11, 2012 | 08:12 PM
marco polo's Avatar
marco polo
nice one Tony thanks for that ..... I have the Dome ones in mine when it was set up by Tal
Old Apr 11, 2012 | 08:15 PM
graham c's Avatar
graham c
mite see if i can find some on sunday and anyone got some pm me
Old Apr 11, 2012 | 08:18 PM
Rsmat's Avatar
Rsmat
Graham if you struggle I will go to the lads house.. I did make copies of mine but haven't had the time to make any.
Old Apr 11, 2012 | 09:43 PM
graham c's Avatar
graham c
Thanks Matt ill see how i get on Sunday if not ill pm you
Old Apr 11, 2012 | 09:45 PM
Rsmat's Avatar
Rsmat
Ok mate.
Old Aug 21, 2016 | 04:04 PM
nixon_2wd's Avatar
nixon_2wd
Anyone know where I can get these nowadays?
Old Aug 21, 2016 | 04:50 PM
cozzy jeff's Avatar
cozzy jeff
i have a set im not using
Old Aug 21, 2016 | 05:09 PM
nixon_2wd's Avatar
nixon_2wd
You have PM mate.
Old Aug 22, 2016 | 01:27 PM
Cosnada's Avatar
Cosnada
I might be interested if he ain't
Old Aug 23, 2016 | 06:22 AM
graham c's Avatar
graham c
You can put two washers on top bolt holes that works too
