caliper/wheel clearance
Old Feb 26, 2005 | 04:21 PM
AJC's Avatar
AJC
Default caliper/wheel clearance
got 300mm discs to go on my s1 and i was intending to use s2 calipers (HI SPEC Conversion),i have been given some escort cos calipers so thought i would try them,
they fit but only have 1mm between insie of rim and caliper,
is this sufficient or am i best of grinding some of the caliper,
cheers
Old Feb 26, 2005 | 04:40 PM
Rippers's Avatar
Rippers
Monte Geek
As long as it doesn't hit the wheel I guess its ok, how about using a 1-3mm spacer if your worried?
Old Feb 26, 2005 | 04:43 PM
AJC's Avatar
AJC
yeah, got some spacers i will try em, cheers pal
Old Feb 26, 2005 | 09:26 PM
S1MAN's Avatar
S1MAN
I run Cossie disc's and calipers on the front of my S1 and there's very little clearance.As the pads have worn the clearance has increased.
Haven't had an problems.
Colin.
Old Feb 26, 2005 | 11:17 PM
AJC's Avatar
AJC
cheers mate, i amm going to put pads in tomorrow and try it
Old Feb 26, 2005 | 11:55 PM
AJC's Avatar
AJC
S1MAN
are your calipers escos with 300mm discs?
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
155lee
14
Aug 22, 2015 12:15 PM
